Used Scope Recommendations?
  • jbbenson
    • Oct 2006
    • 16
    I think I'm ready to add an Oscilloscope to my work bench. Can anyone recommend a nice used model to look for? My main interests are power supplies and audio right now, but I'd like something with a bit of room to grow. I'd like to go into Electrical Engineering at some point, when I'm far enough along in my studies!
  • linuxguru
    • Apr 2005
    • 1564
    Re: Used Scope Recommendations?
    Brands:
    1) Tektronix - just about any model.
    2) Kikusui
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      I love Tektronix, but two models to avoid are the TDS 210 and TDS 220. Both have a common problem that makes one of the two channels unusable. The problem is not fixable (obsolete models, custom part that is not available). Other models are fine; the TDS (and THS) series models all have a similar user interface. Among handhelds, Tek's THS 7x0 models and Fluke's 190 series are pretty cool; the Fluke 90 series is pretty good too.
      PeteS in CA
      • 999999999
        • Sep 2006
        • 774
        IMO, you need to define a budget then hang out on ebay for awhile to get a good idea what that'll fetch... especially late at night, auctions ending in the wee hours can get you an incredible deal sometimes.
        • jbbenson
          • Oct 2006
          • 16
          This may be overkill, but I am now the proud owner of two oscilloscopes.
          One is a Tektronix 453 (acquired locally for a song). The other is an eBay special(powers up/no way to test/no guarantee) Tektronix 7603 with 7A22 and 7B53A plugins. It works, but I'm still debugging power supply issues. Here's the irony: I've nailed the problems down to bad caps, and a couple of fried transistors. It also has a bad case of dust contamination.
          The 453 is in better shape, and works a treat after cleaning the nuvistor sockets in the vertical input preamplifier. I just need to clean up the front panel and lube the cooling fan. It's been quite useful in debugging the 7603.
          • Spacedye69
            • Nov 2005
            • 698
            • US
            I just bought a Tektronix 2465 for $25 (yay me). Its old and I'm sure could use a good going through, but how important is getting it calibrated if I use it for diagnostic/repair kinda stuff? It seems to work fine.
            • Krankshaft
              • Jan 2007
              • 2328
              I'd be careful with that 2465 scope repair wise its a death trap those scopes use custom Large Scale Integrated ICs that Tektronix doesn't manufacure anymore.
              Thats why I stick with my trusty Tek 475 the only scope you don't have to be a rocket scientist to fix .
              As far as calibration thats up to you. If you are using the scope and require time accuracy or an accurate voltage display then calibration is a must.
              However if you're just using it to check pulses to the MOSFETs gate on switchers and observing waveforms then calibration isn't necessary.
              As a general rule though the scope should be checked out to see just how accurate it is and then you can make a decision on calibration.
              Can't beat that price for a working scope though .
