Goot RX-802AS soldering station
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    i have an offer to buy this soldering station. The seller say that this is better even of Weller. The heater is build into the tip, and every tip has a code. You can set temp. for easc code and when you change tip temperature automaticly change to set temp.
    Seller say that this is used in china in manufacturing company. Handle is light and cable is flex. I try it and it's great.
    Do you have any more info on this product?
    ...the quieter you become the more you are able to hear...
  • Ramee
    • Jul 2014
    • 218
    • Israel
    Re: Goot RX-802AS soldering station
    You are right about that, Goot soldering station is made in Japan, planning to buy one but the tweezer type.
      • 31197
      btw, most stuff is better than weller these days.
      it's is not good for comparing against.
        master hoarder
        • May 2008
        • 12175
        That is a very good thing.
        If the tip is built well, the built-in heating element and temperature sensor will give it very good thermal-recovery time. I have a CSI 2600 (Aoyue 2600) that uses the T12 tips (also built-in heating element and TC), and it works very very well - way better than those cheap stations with the 900M tips.
        I say, go for it. But since it's a Chinese station, make sure to open when you get it and redo any bad solder joints or pinched wires. Its a common problem with Chinese stations. Other than that, they are okay.
          07-01-2024, 06:34 AM
        • chth96
          What soldering station should I purchase for 900M-TJ-I tip?
          by chth96
          hello.
          A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
          https://ko.aliexpress.com/item/4001275635593.html
          Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
          Any reply would be appreciated.
          11-24-2023, 05:08 PM
        • caprider
          Recommendations of quality soldering station and (separate) hot air station
          by caprider
          Hey,
          I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
          I now have a TS100 and some soldering irons and looking for some better tools.
          1. Soldering station, budget around 200-240€
          JBC BT-2BWA seems to be a good product in the budget.
          2. Hot air station, budget around 200€
          Up to now I've found ATTEN ST-862D to be a good option....
          01-15-2022, 02:05 AM
        • mkbehbeh
          KSGER C245 Soldering station PSU 220V only?
          by mkbehbeh
          I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
          I am...
          04-17-2023, 03:11 PM
        • Peter_1402
          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
          by Peter_1402
          Hi Everyone,
          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
          1. Soldering iron works great
          2. There is a burnt mark on the hot air gun handle.
          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
          Reed switch tested ok with a magnet.
          From the above test, I can conclude...
          07-12-2025, 11:50 AM
