Suggestions which FLASH programmer to buy...
  • scokljat
    • May 2012
    • 275
    • Croatia
    I need to buy a USB FLASH programmer to erase, program and test 4GB (32Gbx1) K9GAG08U0E-PCB0 TSOP48 NAND FLASH chips and 512KB (4Mbx1) MX25L4006EM1I-12G serial FLASH 8pin SOP chips. Most of all I need comprehensive testing of these chips so I can manage which ones are bad. I have hundreds of these chips removed from bad tablet mainboards...
    I found this cheap programmer on ebay:
    http://www.ebay.com/itm/171341819315...%3AMEBIDX%3AIT
    What do you think of it? Is this programmer and it's software capable of testing/programming my chips, especially 4GB NAND flash TSOP48??
    Any help and suggestion is more than welcome.
    Thanks!
    Cheers,
    Suad
  • scokljat
    • May 2012
    • 275
    • Croatia
    Re: Suggestions which FLASH programmer to buy...
    Anyone? Please...
    S
    • Chriso
      • Jul 2010
      • 30
      Have a look at the EEVblog - there's a huge thread there about it
      I bought mine from Amazon.
      • scokljat
        • May 2012
        • 275
        • Croatia
        Chriso, thank you for the link. Well, is a 39 pages thread, so I suppose answer to my question won't be so easy ;-) Actually, I'm not quite optimistic about this programmer is capable of programing 4GB NAND flash chips...
        S
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          i have the TL866 with many adapters and it is working fine, the released the 6.1 version now. It is simple tu use
          ...the quieter you become the more you are able to hear...
          • scokljat
            • May 2012
            • 275
            • Croatia
            rtstorm, did you try to erase, program and test large TSOP48 4GB NAND flash chips?
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              i did not, most of the time i use them to flash notebook bios. But i also use on MAXIM 29LV008CBTC-70G FLASH MEMORY chip and its doing great.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4913
                • New Zealand
                Stilling running a parallel-port based Willem here... I don't use it much!
                -David VanHorn
                  • 30901
                  NOOOOOoooooooooooooo.................
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4913
                    • New Zealand
                    It works - when you load the right program version.
                    -David VanHorn
                      • 30901
                      but it's like, 1hour per chip or something from what i remember!!!
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4913
                        • New Zealand
                        I guess it would be slower than a USB one. But I haven't seen anything take 1 hour though... but I haven't tried anything over 16Mbit IIRC, which took a few minutes. Most chips I do are very small and are under a minute.
                        I don't even know if it supports anything really huge.. I doubt it.
                        -David VanHorn
                          • 30901
                          i'm doing a lot of 32Mbit chips, and i'm glad i'm using a 48XP to do them!
                          • scokljat
                            • May 2012
                            • 275
                            • Croatia
                            Well, I'm talking about 32Gbit... :-)
                            S
                              • 30901
                              if you just want to do serial nandflash,
                              you can use a modified xd-picturecard reader.
                              those are just nandflash
                              • dj_ricoh
                                • 2073
                                yes yes! but how you read the dam HEX file!
                                my head hurts! pfffff
                                  • 30901
                                  you mean how to read the chip?
                                  well use linux and use the DD command to copy the whole device as sectors to a file.
                                  or there are windows programs to do it, but i cant remember the name.
                                  keep in mind, you probably cant make sense of the dump, it's only good for cloning.
                                  most serial flash uses some type of filesystem.
                                  if you dont know the detail you cant mount it and mess with the content.
                                  also, writing to flash with errors may be an issue because the error mapping may clash with the dump.
                                  these issues arent related to xd-hacks, but effect *all* nandflash programmers.
                                  • Pragmatiko
                                    • Jul 2013
                                    • 468
                                    • IT
                                    SmartPro X8 😉
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4913
                                      • New Zealand
                                      Whichever one has the best software or support. All the fancy hardware in the world won't do anything if they decide to release only some shitty software that only works in Windows 95 or something.
                                      -David VanHorn
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        http://www.ebay.com/itm/TNM-2000-USB...-/321207236799
                                        There is a 5000 model also.
