Suggestions which FLASH programmer to buy...
  • scokljat
    • May 2012
    • 275
    • Croatia
    I need to buy a USB FLASH programmer to erase, program and test 4GB (32Gbx1) K9GAG08U0E-PCB0 TSOP48 NAND FLASH chips and 512KB (4Mbx1) MX25L4006EM1I-12G serial FLASH 8pin SOP chips. Most of all I need comprehensive testing of these chips so I can manage which ones are bad. I have hundreds of these chips removed from bad tablet mainboards...
    I found this cheap programmer on ebay:
    http://www.ebay.com/itm/171341819315...%3AMEBIDX%3AIT
    What do you think of it? Is this programmer and it's software capable of testing/programming my chips, especially 4GB NAND flash TSOP48??
    Any help and suggestion is more than welcome.
    Thanks!
    Cheers,
    Suad
  • scokljat
    • May 2012
    • 275
    • Croatia
    Re: Suggestions which FLASH programmer to buy...
    Anyone? Please...
    S
    • Chriso
      • Jul 2010
      • 30
      Have a look at the EEVblog - there's a huge thread there about it
      I bought mine from Amazon.
      • scokljat
        • May 2012
        • 275
        • Croatia
        Chriso, thank you for the link. Well, is a 39 pages thread, so I suppose answer to my question won't be so easy ;-) Actually, I'm not quite optimistic about this programmer is capable of programing 4GB NAND flash chips...
        S
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          i have the TL866 with many adapters and it is working fine, the released the 6.1 version now. It is simple tu use
          ...the quieter you become the more you are able to hear...
          • scokljat
            • May 2012
            • 275
            • Croatia
            rtstorm, did you try to erase, program and test large TSOP48 4GB NAND flash chips?
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              i did not, most of the time i use them to flash notebook bios. But i also use on MAXIM 29LV008CBTC-70G FLASH MEMORY chip and its doing great.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5012
                • New Zealand
                Stilling running a parallel-port based Willem here... I don't use it much!
                -David VanHorn
                  • 31144
                  NOOOOOoooooooooooooo.................
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5012
                    • New Zealand
                    It works - when you load the right program version.
                    -David VanHorn
                      • 31144
                      but it's like, 1hour per chip or something from what i remember!!!
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5012
                        • New Zealand
                        I guess it would be slower than a USB one. But I haven't seen anything take 1 hour though... but I haven't tried anything over 16Mbit IIRC, which took a few minutes. Most chips I do are very small and are under a minute.
                        I don't even know if it supports anything really huge.. I doubt it.
                        -David VanHorn
                          • 31144
                          i'm doing a lot of 32Mbit chips, and i'm glad i'm using a 48XP to do them!
                          • scokljat
                            • May 2012
                            • 275
                            • Croatia
                            Well, I'm talking about 32Gbit... :-)
                            S
                              • 31144
                              if you just want to do serial nandflash,
                              you can use a modified xd-picturecard reader.
                              those are just nandflash
                              • dj_ricoh
                                • 2073
                                yes yes! but how you read the dam HEX file!
                                my head hurts! pfffff
                                  • 31144
                                  you mean how to read the chip?
                                  well use linux and use the DD command to copy the whole device as sectors to a file.
                                  or there are windows programs to do it, but i cant remember the name.
                                  keep in mind, you probably cant make sense of the dump, it's only good for cloning.
                                  most serial flash uses some type of filesystem.
                                  if you dont know the detail you cant mount it and mess with the content.
                                  also, writing to flash with errors may be an issue because the error mapping may clash with the dump.
                                  these issues arent related to xd-hacks, but effect *all* nandflash programmers.
                                  • Pragmatiko
                                    • Jul 2013
                                    • 468
                                    • IT
                                    SmartPro X8 😉
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5012
                                      • New Zealand
                                      Whichever one has the best software or support. All the fancy hardware in the world won't do anything if they decide to release only some shitty software that only works in Windows 95 or something.
                                      -David VanHorn
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        http://www.ebay.com/itm/TNM-2000-USB...-/321207236799
                                        There is a 5000 model also.
                                        • what_1282105
                                          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                          by what_1282105
                                          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                          02-14-2025, 07:27 PM
                                        • ugamazing
                                          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                          by ugamazing
                                          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                          08-31-2022, 07:34 AM
                                        • ekozeko333
                                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                          by ekozeko333
                                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                          🔥 The Problem Started After Suspected ESD/PD Fault
                                          I experienced a power issue or ESD event through a USB-C charger
                                          After that, the NX20P5090 power switch was visibly burned and was replaced
                                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
