Goot PX-201
  • Super Nade
    • Jun 2006
    • 294
    Goot PX-201
    Folks,
    After putting up with shit Radiocrap soldering irons, I finally got a decent Goot PX-201 from Bomir. It was more of a necessity as I ruined a PCB today (f!$!%ing hell!). $57.xx shipped for it + a replacement tip.
    http://www.bomir.com/online/?sub=441
    I'm curious to see how well the temperature controller on the pencil works. What sealed the deal for me was the 70W output and the 450 C max (a bit low for recapping..but anything else is out of my budget). It's a bonus that it comes with some sort of temperature adjustment. I'm not sure if it is feedback controlled or not..
    Any other Goot guys here?
    Some info:
    * High Output Ceramic Heater (70Watts)
    * Lead Free Compatible due to large high output heater.
    * Accurate control of the tip temperature: There is a temperature control in the handle for easy adjustment.
    * Ergonomic Handpiece Grip.
    * Light and comfortable to use in the field or on the workbench.
    * Wide variety of tips available.
    * Heat insulation cap for quick storage for field technicians.
    * Power Monitor Lamp to indicate when power is on.
    Voltage : 110-130, 220-240V AC 50/60Hz
    Power Consumption: 70W
    Temperature Setting Range: 250-450 °C
    Insulation Resistance (500V DC): Over 100MΩ
    Temperature Control System: Sensor Feedback ( ON-OFF Control)
    Length: 210mm (w/o cord bushing)
    Weight: Approx. 90g (w/o cord)
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • Harvey
    • Apr 2007
    • 264
    Re: Goot PX-201
    Looks nice I've never heard of Goot myself.
    I doubt you'll find 450C too low though if you've got 70W behind it. I currently use a 48W that goes up to 420C and I've never needed that higher than about 400C, just don't make the mistake of using a really small pointed tip... use something like a 5mm and it stays hot while you wait for the solder to melt.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Goot PX-201
      goot's stuff is excellent
      but i think you would be better served with the 2mm chisel tip PX-2RT-2D
      • Super Nade
        • Jun 2006
        • 294
        Re: Goot PX-201
        I should have gotten the 5mm replacement instead of the extra 0.3mm. Most of my work is with PCB touch-ups (I have to do this after ruining my laser's servo-lock board with the God-damn POS $15 Radiocrap iron...man I'm pissed today).
        Goot have piss poor distribution in the US. But those in the Oceania region i.e Aussies and Kiwis have widespread access.
        Edit#
        Willa, would you prefer tip-tinning compound over tinning mesh? Any maintainence suggestions?
        Q6700 @ 3.6 GHz
        Zippy GSM-6600P
        Abit IP35Pro
        ATi HD4870
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: Goot PX-201
          Goot is another japanese company like Hakko. Unfortunately they have poor distribution and promotion around the world for such good products but there are distributors around. Hakko is better promoted.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Goot PX-201
            i was using some of this periodically
            http://www.goot.co.jp/ENGLISH/catalo...chemi/BS2.html
            but really i just tin the tip with solder and try to keep it clean while working with wet sponge. takes a lot of soldering to mess up good tips but in the end just get a new tip.
            its good to use one tip for pcbs and keep it nice, then have another for various other general messy jobs like audio cables, electrical.
            • Super Nade
              • Jun 2006
              • 294
              Re: Goot PX-201
              Copy that. I'm keeping one for the PCB's. My next order will probably be a full complement of replacement tips along with the tinning compound you suggested. Thanks man.
              Q6700 @ 3.6 GHz
              Zippy GSM-6600P
              Abit IP35Pro
              ATi HD4870
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: Goot PX-201
                that iron has a ceramic heater. make sure you dont drop it from a height otherwise you break it
                • Super Nade
                  • Jun 2006
                  • 294
                  Re: Goot PX-201
                  Copy that. I was scanning through the other offerings and I came across a "lead free soldering iron". How the hell is it different from any other iron? I always thought the solder is what matters...Can I use this pencil with lead-free solder?
                  Q6700 @ 3.6 GHz
                  Zippy GSM-6600P
                  Abit IP35Pro
                  ATi HD4870
                  • linuxguru
                    • Apr 2005
                    • 1564
                    Re: Goot PX-201
                    Goot is a brand of Taiyo Electric Industries Ltd., Japan - they're among the best of the inexpensive (<$10) plain-old soldering irons in the market.
                    Lead-free solder usually has a higher melting point, so you'll need a hotter/higher-powered iron. The tip also needs to be resistant to dissolving in tin, if it's a high-tin solder. Many metal tips are copper, clad with a thin layer of iron/nickel - these will corrode rapidly with high-tin solders. Goot's ceramic tips are among the best I've seen for high-tin solders - they don't corrode, and they're easily cleaned with a soft sponge or similar when hot.
                    • Super Nade
                      • Jun 2006
                      • 294
                      Re: Goot PX-201
                      It arrived yesterday and I'm in love with it. The grip is very comfortable and just as the manual states, cool down time is approximately 3min. How do I benchmark this against the shit Radiocrap iron I have?
                      Q6700 @ 3.6 GHz
                      Zippy GSM-6600P
                      Abit IP35Pro
                      ATi HD4870
                      • Kaine
                        • Mar 2007
                        • 55
                        Re: Goot PX-201
                        wait, what?
                        moving on.
                        I bought myself a nice Duratech copy of a Hakko station recently for ~$90. It's not fancy, but it heats up real quick and is plenty hot enough. 50W, 480c max, ceramic element. Just wish i could find a better (read "bigger") tip for it. Using it on anything but tiny boards right now is like knitting with a sewing needle.
                        You don't. It's like being beaten as a child. You take your lessons from the painful memories and move on; now the healing can start.
                        • edugimeno
                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                          by edugimeno
                          Hi!!
                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                          At a certain point, moving stuff around, I put all wires back in place and...
                          03-24-2024, 02:31 PM
                        • nop
                          Busted tankless electric water heater control board
                          by nop
                          Hi. I have an old Bosch/Powerstar AE125 water heater in my cabin whose control board died for the nth time. This time around, I figured I'd try to diagnose and repair it. At the end of the board's life its power indicator LED will quickly cycle on and off as water passes through the heater, rather than remaining steadily on as it normally would, and water at the tap remains cold. Slightly increasing pressure in the system by closing the outlet valve seems to delay the inevitable for a little while.
                          Here's all the info I found from Bosch regarding troubleshooting the board:
                          04-27-2022, 09:57 AM
                        • CapLeaker
                          AcuRite 5 in 1 temperature sensor replacement repair
                          by CapLeaker
                          Got a new victim:
                          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                          B: stuck at some temperature and maybe updating once in 12 hrs or so.
                          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                          04-15-2025, 01:32 PM
                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                          12-16-2023, 08:39 PM
                          03-31-2024, 02:12 PM
