Hi. I have an old Bosch/Powerstar AE125 water heater in my cabin whose control board died for the nth time. This time around, I figured I'd try to diagnose and repair it. At the end of the board's life its power indicator LED will quickly cycle on and off as water passes through the heater, rather than remaining steadily on as it normally would, and water at the tap remains cold. Slightly increasing pressure in the system by closing the outlet valve seems to delay the inevitable for a little while.
Here's all the info I found from Bosch regarding troubleshooting the board:
My meter (a cheap one) shows over-range between the leads marked in the troubleshooting diagram for each triac on the broken board. However, it does the same on the new board I replaced it with (which works perfectly). The resistance between the outside leads on each thyristor on both boards is about 29 ohms. So it seems the thyristors are not the problem?
Here are some photos. FWIW, I can't see any cracked joints or other obvious problems.
Any advice? Thanks!
Any advice? Thanks!
