LGA 1700 Socket Replacement Tips & Tricks
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hi All,
    Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
    I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
    Questions:
    1: I noticed another thread has a socket replacement guide from ASUS which recommends placing 2x4 wood blocks on the each side to stop the board from warping, is this still required on smaller MATX boards?
    2: Since I'm using the heat pad is it still recommended to ramp your hot air temperatures slowly? Say starting at 200 and ramping 50c every 30 seconds? Trying to mimic heat profiles on BGA rework station.
    3: The sockets I've ordered still have the protection cover on them. I was planning to leave them on to provide heat protection to the socket, and also apply some aluminum tape to the top again for the same purpose. Thoughts? Just covering the top not the sides otherwise I'll likely to stick to the board and end up with ball squeezage. I'm concerned the top cover may melt slightly and deform making it difficult to take off once the sockets installed.
    Any other things I should take into consideration?
    Thanks for the advice!
  • Aliencomputres
    • Aug 2019
    • 208
    • România
    Originally posted by AJ847.63e
    Hi All,
    Questions:
    The socket replacement procedure is quite complicated for amateurs. And from an economic point of view it may be useless.
    • AJ847.63e
      • Aug 2020
      • 171
      • Africa
      Yeah I know, that's exactly why I do not want to invest too much into equipment to assist with it. TBH this boards pretty cheap as well, $130 for a new one so yes it's not worth it.
      That's not why I'm doing it though. I'm doing it as a learning experience to try improve my skills. The boards dead. 6 beeps and wont post. So what's the worst that can happen? It will be a good learning exercise and was hoping to get some do's and don'ts so I can give myself the best chance at it working first time.
      Instead of screwing up the 2 sockets I bought and me wanting to buy more of them because I think I've solved all the issues and want to try again.
      • Aliencomputres
        • Aug 2019
        • 208
        • România
        6 beeps and wont post-Video Card Not Seated Properly/Video Card Power Issues
        Faulty Motherboard: In rare cases​
        • AJ847.63e
          • Aug 2020
          • 171
          • Africa
          Highly doubt it's not a socket issue as this was a brand new board we were using for a new build, and have already done the troubleshooting on it. It wont be a PCIE/GPU issue as we tried a non F CPU (i5 12400) and it still had the same issue. I can see multiple bent pins hence why I went to the socket replacement. Could still be a board fault but highly unlikely.
          • Aliencomputres
            • Aug 2019
            • 208
            • România
            It would have been great if you had told us from the beginning that there were defective pins in the socket.
            • AJ847.63e
              • Aug 2020
              • 171
              • Africa
              Sorry I thought that was self explanatory hence why I did not mention it.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                I doubt those "heat mats" used for phones and tablets can get hot enough to assist you enough with replacing the socket.... though I haven't used one (or even seen one) so I don't know how hot they get.
                In any case, you will need a lot more heat, probably.
                If you have an electric (but NOT induction type) or gas stove / cooktop / burner (almost every household does), you can use that as your bottom heater. It's not a neat solution, but it does work and I have used it many times to remove large CPU sockets even without the need for hot air, and the boards were not damaged. The way to do it is to place the board on blocks of wood above the burner, about 4-8 cm away, depending on how strong your burner/cooktop is. For gas-operated burners, I prefer to keep it a little higher so that the flames don't actually touch the PCB. For electric, the distance can be smaller, depending on the type. The coiled "exposed" burners can be effective even at a medium distance. But ceramic and/or enclosed or the flat IR ones that "glow red", you might have to shorted the distance.
                Whatever you use, you will need a type-K thermometer to constantly monitor the temperature of the board (these are about $10 online.) Something like the Lutron TM-902c will do (this is what I have, but I'm sure other types exist too.) And IR thermometer gun and infrequent temperature checking will NOT do. Basically, you'll be looking to heat the board to at least 150-180C before you can start hitting it with your hot air gun. Anything less, and you will probably have too much heat from the top and not enough on the bottom, making it more likely to rip a pad under the CPU socket.
                BTW, another DIY alternative to the stove/cooktop/burner is to make your own bottom heater from an old toaster. There was a member here that did that, though it's a very old post and I'm not sure I'll be able to find it easily. But the idea is the same - you need about 500-800 Watts of heat minimum for your bottom heater, because any even remotely modern board will suck up the heat very efficiently.
                • AJ847.63e
                  • Aug 2020
                  • 171
                  • Africa
                  Thanks for the advice. The heat mats can only go up to 120 Celsius, haven't seen one that goes higher than that. So most likely wont be enough but it's better than nothing.
                  I managed to remove the socket no problems, but holly crap it took a ton of heat! Shocked how much these sockets can take it does not even look slightly singed. Not a single ripped pad either shockingly..... Until stupid me ripped a few pads while wicking, I really need to get rid of this gootwick crap! I do not understand how people use it, it's more keen to open it's legs than a lady of the night.
                  It's always the easy stuff I screw up on GRRR.....
                  I'm a bit confused. One board view I have says one of the ripped pads is VCC_SA, and another BV says that exact same pin is ground. Trying to read the board I cannot see any trace coming out of the pad so it looks like it's via under pad so I do not have anywhere to grab the line from.
                  How is that possible? I thought the pinout would have to be the same on all boards because they all use the same socket? How could the pinout be different? Or is this just a case of the typical BV is wrong again?
                  • elisest
                    TBK R-2201 for CPU socket replacement
                    by elisest
                    I have some intel socket motherboards that require new sockets and I'm contemplating purchasing a TBK R-2201 to carry out the works. but I can find hardly any information about it especially reviews for the unit.
                    Does anyone have any experience or knowledge of this machine, it looks suitable for socket replacement but is it?? Any help would be greatly appreciated, thanks.
                    this is the website for it :
                    TBK220Intelligent Thermal Infrared Imager Analyzer BGA Rework Station
                    12-28-2024, 08:55 AM
                  • Geomih
                    CPU socket replacement soldering profile
                    by Geomih
                    Hi All - I am hoping someone can help with some pointers (complete noob here!)
                    I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                    My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                    The simple stuff like a small memory module isn't a big deal because there are
                    12-11-2023, 11:07 AM
                  • mrsdsdsdsd
                    4G LTE router sim socket replacement
                    by mrsdsdsdsd
                    hi everyone i hope you all doing well.
                    i'm trying to replace a sim socket in my 4g router, i found similar parts on aliexpress and i'm not sure if it will work on my device (Huawei b593s-22)
                    here's the original one:
                    and here's the links of the one i found on aliexpress:
                    1-
                    https://www.aliexpress.com/item/1005...yAdapt=glo2vnm
                    2-
                    https://www.aliexpress.com/item/4001...yAdapt=glo2vnm
                    if anyone knows if it is possible to replace it with either one please let me know.
                    thank you...
                    06-02-2024, 12:49 PM
                  • dicky96
                    PCIe x16 socket replacement / desolder / rework
                    by dicky96
                    I sometimes see expensive motherboards sold spares/repair with damaged or burnt PCIe x16 sockets
                    So I started to wonder, it is possible to de-solder the faulty socket and fit a replacement? At least for the non-armoured type
                    To this end I thought I would try to desolder a PCIe 16x socket from a scrap board - without damaging the board. The thought was, if I can remove the old socket and clean out the through holes, then fitting a new one should not be a problem
                    From googling - According to people responding to questions asking about doing this on computer/tech...
                    04-14-2021, 04:06 PM
                  • Prott
                    Soldering flex cable - tips & tricks
                    by Prott
                    Hello fellow badcappers,
                    I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
                    I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
                    10-04-2023, 06:25 AM
