Everyone is buying the wrong CH341 programmer
  • lotas
    • Jan 2016
    • 4472
    • Russia
    Measure the voltage in the laptop between 4 and 8 pins, and then you will know what voltage the spi flash is designed for.
    • Billy1690
      • Aug 2024
      • 46
      • United Kingdom
      Hi buddy im getting 3,353 is that about right
      • lotas
        • Jan 2016
        • 4472
        • Russia
        Yes, its supply voltage is 3.3v
        • Billy1690
          • Aug 2024
          • 46
          • United Kingdom
          Ive been flashing recommended dump files on the chip with 3.3V and still get the flashing cap lock is it possible this programmer isn't detecting the correct chip as i cant see the number on the chip as its worn away to put it in manualy
          • lotas
            • Jan 2016
            • 4472
            • Russia
            First you need to look at what the protection (status register) is (remember, it may be useful in the future), remove the protection (status register), then erase and write dump...
            • Billy1690
              • Aug 2024
              • 46
              • United Kingdom
              #26
              Can i use the protection status register settings on this ezp2023+ or is it something i would need to read up on
              • lotas
                • Jan 2016
                • 4472
                • Russia
                #27
                I don’t have such a “programmer”, and in my opinion it cannot work with status registers.
                • Billy1690
                  • Aug 2024
                  • 46
                  • United Kingdom
                  #28
                  Does this programmer XGecu T48 support status register
                  • lotas
                    • Jan 2016
                    • 4472
                    • Russia
                    #29
                    Yes, maybe CH341A can do it too with the program "NeoProgrammer V2.2.0.10".
                    • Billy1690
                      • Aug 2024
                      • 46
                      • United Kingdom
                      #30
                      Brilliant Lotas looks like im gonna get the XGecu T48 ill look on Aliexpress shortly thanks again for all your advice
                        • 30937
                        you can test the T48 software in demo-mode to see if it has the features you want.
                        http://forums.xgecu.com/viewthread.php?tid=20
                        here is the goods
                        https://www.aliexpress.com/store/480...26abbperbperpr
                        • Billy1690
                          • Aug 2024
                          • 46
                          • United Kingdom
                          #32
                          Cheers Stj as soon as I get one you can help me set it up 👍😄
                          • Billy1690
                            • Aug 2024
                            • 46
                            • United Kingdom
                            #33
                            That’s it ordered thanks buddy 👍😉
                            • CuriousDave
                              • Aug 2024
                              • 11
                              lotas is right about the clips. If you work with the BIOS often or not, better have the adapters. I bought the adapters cost less than $10 each and some are selling less than $5. The pins do not have enough space to use alligator clips.
                              • harp
                                • Jun 2022
                                • 592
                                • Planet Earth
                                #35
                                "The pins do not have enough space to use alligator clips." Here is method how to overcome this issue http://www.youtube.com/watch?v=SrAzVT1OKEA
                                • Billy1690
                                  • Aug 2024
                                  • 46
                                  • United Kingdom
                                  #36
                                  Yes i binned the alligator clips and got adapters and a T48 programmer great bit of kit ive programmed a W25Q64FVSSIG bios chip not fitted it yet but fingers crossed
                                    • 30937
                                    nice.
                                    the software can run in Linux btw - you just need an extra DLL file i can post.
                                    • Billy1690
                                      • Aug 2024
                                      • 46
                                      • United Kingdom
                                      #38
                                      Dont have Lunix im on windows buddy but thanks anyway good to know are there any special settings i use for the T48 programmer to copy & wright a bios file or will default settings be ok
                                        • 30937
                                        just select the chip - thats pretty much it.
                                        • Billy1690
                                          • Aug 2024
                                          • 46
                                          • United Kingdom
                                          #40
                                          Brilliant pal thank you im gonna fit the chip tomorrow so fingers crossed this flashing cap lock thing disappears and it boots up ill keep you posted pal thanks again for your help
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • dicky96
                                            CH341 Programmer - any good for 1.8V?
                                            by dicky96
                                            Hi guys
                                            I have a TL866 CS Eprom programmer and up until now it did everything I needed to do
                                            However for the first time I have come across a 1.8V Eprom and my programmer will not do 1.8V
                                            I need to program a 25Q64FWTG
                                            I could splash the cash and buy a V11.71 TL866II. These come with various attachments and the kit including a 1.8V adapter is either €62 with 12 adapters or €68 with 1 7adapters. I also have the option to buy just the programmer for €46.70, if I could get the 1.8V adapter separately and use the other eprom adapters from...
                                            01-31-2022, 06:14 AM
                                          • Teeheeze
                                            RT809H Programmer Firmware Corrupted
                                            by Teeheeze
                                            This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                                            02-13-2025, 04:51 PM
                                          • Jeff'sTech
                                            Dell Latitude 7420 BIOS Unlock Gone Wrong
                                            by Jeff'sTech
                                            Hello everyone.
                                            I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                            11-08-2023, 03:30 PM
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
