Can the CH341A chip be programmed?
  • hadyshahat
    EGYPT
    • May 2023
    • 35
    • Egypt
    Is it possible to program the CH341A chip, because I bought a replacement part and replaced the damaged one, but the programmer does not read?
    Please help​
    • 31011
    ch341a does not contain any data - something else maybe wrong - check it's getting power
      • 20781
      Please help​
      What chip are you trying to read. Which CH341A do you have, post a picture, and what software version are you using.
      • harp
        • Jun 2022
        • 598
        • Planet Earth
        You have to inspect every track for connections and voltages, according to schematic.
        What is the reason to chip die?
        • hadyshahat
          EGYPT
          • May 2023
          • 35
          • Egypt
          I bought a new chip for the programmer because the old chip was damaged and the new one when I installed it did not read on the computer and it does not sense it at all and the program I am using is version 2.2.10 it is the best program and I have been working on it for a long time because it is a very good program but the programmer does not read on the computer
          • hadyshahat
            EGYPT
            • May 2023
            • 35
            • Egypt
            The reason for the chip damage is that the IC was installed in the opposite direction, so the CH341A chip reached a high temperature and burned out.
              • 31011
              post a picture of the board.
              • Sparklingx
                • Jul 2024
                • 41
                • Bangladesh
                hi what is the job of "pin 25" ? In my programmer pin 25 is not soldered but mine works fine(read,erase,write,verify)
                • hadyshahat
                  EGYPT
                  • May 2023
                  • 35
                  • Egypt
                  These are pictures of the programmer.
                  • Sparklingx
                    • Jul 2024
                    • 41
                    • Bangladesh
                    you can try one thing connect a capacitor from GND to VDD then try. your's and mine are same board and chip(CH341B not A)
                    • harp
                      • Jun 2022
                      • 598
                      • Planet Earth
                      In that case, check also fuse and vreg. The soldering job... I will redoing that, it not look promising. At least, check that you dont have mechanicaly loosing legs of IC (say... crucial pin#14 X0 looks like bumped by cold joint) by slightly pushing every pin by its side - it must staj firm, no any movement... and check to pin by pin do not touch by side eg pin#1 and #2... use flux in the proces.
                      Put back C2 also, it is 100nF on 3.3v rail.
                      • hadyshahat
                        EGYPT
                        • May 2023
                        • 35
                        • Egypt
                        The computer does not read the original programmer.
                        • harp
                          • Jun 2022
                          • 598
                          • Planet Earth
                          If power led turn on when connecting to working USB, then check if you have 3.3v present.
                          If LED stay off while inserted into usb, you have
                          - not vorking usb or
                          - not working led circuit or
                          - blown fuse or
                          - short on pcb
                          Check all that and report back with info.
                            • 20781
                            The LED has green corrosion on one pad,and on the other its blackened. C1 looks like its metal ends are missing. The USB socket pins might have some corrosion on them. C2 is broken/missing. The soldering on the F1 fuse doesn`t look too good. Besides all that the 16 pin socket is very dirty inside.
                            Did you check the fuse,voltage regulator and xtal.​
                              • 31011
                              do you see the power led light up?
                              if not check the fuse-resistor,
                              if you do then look at the 12MHz crystal and it's 2 caps
                              • hadyshahat
                                EGYPT
                                • May 2023
                                • 35
                                • Egypt
                                The measurements are correct for a working LED but my computer does not recognize it.
                                • lotas
                                  • Jan 2016
                                  • 4583
                                  • Russia
                                  Update your driver. https://www.wch-ic.com/downloads/CH341SER_EXE.html
                                  https://www.wch-ic.com/downloads/CH341PAR_ZIP.html
                                  • hadyshahat
                                    EGYPT
                                    • May 2023
                                    • 35
                                    • Egypt
                                    The problem is not in the definition, the problem is in the IC
                                    • rogfanther
                                      • Jul 2006
                                      • 458
                                      • Brazil
                                      Can you measure the voltages in U1 ? Also, please re-check the soldering of the usb connector.
                                      • CuriousDave
                                        • Aug 2024
                                        • 11
                                        I am just wondering how much the programmer cost where you live. Isn't it cheaper to buy the programmer instead of trying to fix it? I just bought a new one from Amazon to find out if it reads the T2 ROM and it cost about $12 with two TSOP adapters and cables.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          How to add chip support to NeoProgrammer software for the CH341A Programmer
                                          by SMDFlea
                                          Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                          and once you do find them there`s a few crucial steps missing.
                                          Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                          Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                          After adding the chip save the xml file and copy it to the root directory of the...
                                          05-26-2024, 07:15 AM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                          by SMDFlea
                                          Bad...
                                          09-02-2021, 04:40 PM
                                        • intelg
                                          HP Elitedesk 800 G6 lost BIOS admin password
                                          by intelg
                                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                          Here is the hardware identification specs:
                                          HP EliteDesk 800 G6 Desktop Mini PC
                                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                                          Born on date: 07/26/2021
                                          SN MXL11841GN
                                          SKU 3X8V9UCHABA
                                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                          SYSTEM BOARD ID 8710
                                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                          11-03-2023, 02:05 AM
