Can the CH341A chip be programmed?
    • 31188
    it's a 3.3v device - isnt the T2 rom 1.8v?
    • Sparklingx
      • Jul 2024
      • 41
      • Bangladesh
      Originally posted by CuriousDave
      I am just wondering how much the programmer cost where you live. Isn't it cheaper to buy the programmer instead of trying to fix it? I just bought a new one from Amazon to find out if it reads the T2 ROM and it cost about $12 with two TSOP adapters and cables.
      I got mine for a discount, 4.5$ including test clip & 2 sop16/8 - dip8 board
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
        How to add chip support to NeoProgrammer software for the CH341A Programmer
        by SMDFlea
        Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
        and once you do find them there`s a few crucial steps missing.
        Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
        Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
        After adding the chip save the xml file and copy it to the root directory of the...
        05-26-2024, 07:15 AM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
