Owon HDS2202S oscilloscope
  • danro
    • Aug 2011
    • 55
    • Serbia
    I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
    It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
    It seems to be an LDO regulator. I identified it like this:
    Pin1 - Vin
    Pin2 - GND
    Pin3 - ? (connected with pin1)
    Pin4 - ADJ ? (resistive divider between Vout and GND)
    Pin5 - Vout
    Marking: CHANt
    Thank you,
    danro
    • 31288
    does it have an inductor or is it linear?
    • danro
      • Aug 2011
      • 55
      • Serbia
      No inductor
      It is linear
      I think is similar with SL9650 - ADJ, but not sure about Vout value
      (https://www.slkoric.com/ldo/SL9650M33SE.html)
      • harp
        • Jun 2022
        • 648
        • Planet Earth
        Have you see:
        https://www.eevblog.com/forum/testge...in-dmmawg/675/
        • R_J
          • 9624
          The CHAxx is a SGmicro SGM2033-ADJXN5G/TR (250ma) VS the SGM2019 (300ma)
          • danro
            • Aug 2011
            • 55
            • Serbia
            Sorry but I was away for a few days. Thank you all for the answer.
            Ok, CHAXX is SGM2033-ADJ
            In my case R1=110k (05D) and R2=39k (393) it results that Vout = 1.2 x (1+R1/R2) = 4.6V
            Locally I can't find a supplier for this IC, but I think I can use AP2210K-ADJTRG1 without any modification, having Vout= 1.24 x (1+R1/R2)= 4.74v. Another option would be to use AP2210K-5.0TRG1
            Which one do you think would be better use?
            Regards​
            • Agent24
              I see dead caps
              • Oct 2007
              • 5094
              • New Zealand
              If the original design was set to specifically 4.6v output then there must be a reason for that.
              Going higher to 4.74v or even 5v is probably not a good idea. You may damage something or cause incorrect operation.
              Either get the correct chip or change the resistors so you get 4.6v from a different chip.
              -David VanHorn
              • praveenramavath
                Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                by praveenramavath
                Hello All,
                I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                https://www.hifivision.com/threads/m...-screen.98243/
                Troubleshooting Summary: Majority Internet Radio - Flash Chip
                04-26-2025, 09:08 AM
              • Tarot Superstars
                How not to Damage an Oscilloscope
                by Tarot Superstars
                Hello.
                I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                I want to learn how not to damage it, and I found instructions on the internet obscure.
                They talk about ground, earth, floating ground, this, that....
                But they don't actually say anything anything useful so far.
                I want to know:
                Don't connect exactly this to exactly there or it blows up.
                For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                I want to know what not to connect...
                08-29-2023, 02:27 PM
              • Evets
                Dynamco analogue oscilloscope
                by Evets
                I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                08-30-2024, 06:54 AM
              • SolomonMan
                Vintage BK Precision 1403 Oscilloscope....
                by SolomonMan
                All,
                Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                12-03-2023, 10:39 PM
              • Bartoloni
                Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                by Bartoloni
                Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                replaced the capacitor (330) and the inductor (R15) without any change
                any idea? very thank you!
                input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                12-09-2024, 12:42 PM
