Fundamentals of Digital Oscilloscope Usage
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: Fundamentals of Digital Oscilloscope Usage
Not digital, but still oscilloscope:
NJARC Oscilloscope School a.k.a. "Scopes For Dopes"
Fundamentals of oscilloscopes
http://www.youtube.com/watch?v=8ZKMrzTGxLQ
Discussion thread on eevblog : http://www.eevblog.com/forum/beginne...ss-%28long%29/
To make it easier to navigate this long video - over 2 hours long, here is a list of time-stamps and the topics that begin at those timestamps. Using this "table of contents", you can easily move the youtube player location to the topic of interest.
0:00:00 Opening and Agenda
0:02:50 Brief History of Oscilloscopes – with Al Klase
0:15:00 Start of Basics of Oscilloscopes – with Alan Wolke
0:19:00 Basic Block Diagram of an Oscilloscope
0:19:50 Oscilloscope / Display Overview
0:23:00 Display Section Functions and Controls
0:28:10 Vertical Section Description
0:33:17 Vertical Scale / Coupling Controls, Input Impedance
0:38:04 Vertical Mode Controls
0:48:05 In-circuit Example of using two traces on the oscilloscope
0:52:41 Horizontal Section Description
0:53:48 Horizontal Sweep Types & Controls
1:10:15 Triggering (Synchronization) Section Description
1:13:19 Trigger Source, Mode and Coupling Controls
1:19:56 Trigger Level and Slope Controls
1:23:29 Introduction to Oscilloscope Probes
1:31:45 1X and 10X Passive Probes
1:34:00 10X Probe Compensation and Use Considerations
1:48:48 XY Mode of Operation
2:00:12 Front Panel Control Layout
2:02:20 Pop Quiz!
2:03:00 Wrap Up: Oscilloscope adds Intuitive Feel to circuit operation
2:04:45 Questions and Answers
2:13:35 Brief History of Oscilloscope Tubes
http://www.youtube.com/user/w2aew/vi...ow=grid&view=1 -
@mariushm, good links, thanks.Never stop learning
Hello.
I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
I want to learn how not to damage it, and I found instructions on the internet obscure.
They talk about ground, earth, floating ground, this, that....
But they don't actually say anything anything useful so far.
I want to know:
Don't connect exactly this to exactly there or it blows up.
For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
I want to know what not to connect... -
Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
Also fixed A LOT of cold solder joints and also done some modifications,...-
Recently my father-in-law sent my wife and I out to Arkansas from SLC, Utah to pick up a van. Weird, but true. My father-in-law owns an auto repair shop and found this beefed-out van with a wheelchair lift (I guess those are really expensive).
The woman we picked it up from was getting rid of her father's estate after he passed.
While we were there - she had opened his garage to give us the extra seat for the van - I saw an oscilloscope sitting in the corner. I guess the guy was an engineer. One of the really really smart ones that worked on projects 12 levels above... -
by kuba2102Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...01-06-2025, 09:14 PM -
by wolf1976hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
is there ?
do you have to suggest me one ?
thanks on advance... - Loading...
