noob getting started and wondering what flux types there are or what to buy
  • daRk_Kon
    • Apr 2007
    • 109
    what flux do you recommend to be used on motherboards or graphics cards?
    also,
    what briad is best to be used here? width wise that is.
    http://www.hmcelectronics.com/cgi-bi...uct/1530-0028/
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: noob getting started and wondering what flux types there are or what to buy
    i dont use either
    • daRk_Kon
      • Apr 2007
      • 109
      do you use dental picks or something willawake?
      also which solder wire is best?
      http://www.hmcelectronics.com/cgi-bi...at_id=119&pg=2
      sorry i cant reedit my post to put this in.
      if im missing something, please tell me because i am in need of some direction on what to buy and what is good quality and bad out there. thanks
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Might not be too much help but also don't think we've had many discussions 'bout this...
        https://www.badcaps.net/forum/showthread.php?t=2497
        • daRk_Kon
          • Apr 2007
          • 109
          that helps a little, we almost need like a guide specifying whats good to use for what lol.
          • daRk_Kon
            • Apr 2007
            • 109
            check out what i found, i figure it might be helpful for anyone wondering the different types of solder.
            60/40 Solder: Composed of 60% tin and 40% lead, this solder melts at 374oF, but doesn't become completely solid until it cools to 361oF. This means it has a "pasty range" or "working range" of 13 degrees. This solder is your best choice for copper foil work. The liquid temperature and narrow "pasty range" make it easy to form and maintain consistent high, rounded, beaded seams. Because of its relatively low melting point, "60/40" solder is easy to rework to maintain a smooth finish solder bead.
            50/50 Solder: This is composed of 50% tin and 50% lead. It is liquid at 421oF, solid at 361oF and has a pasty range of 60 degrees. This solder will produce a much "flatter" bead than 60/40. Because of its higher melting point, 50/50 solder is often used on the back (or inside) of a stained glass project to protect against "melt through" when soldering the front. Because it spreads and flattens out, 50/50 solder is often used when soldering lead came joints.
            63/37 Solder: This solder is 63% tin and 37% lead. It becomes liquid at 361oF, and solid at 361oF, with a pasty or working range of 0 degrees. This solder is called a eutectic alloy which means at 361oF, you can go instantly from solid to liquid to solid just by applying or removing the heat source. You will often find "63/37" solder referred to as decorative or quick set solder. It is primarily used to create dimensional effects in the solder itself and can be "pulled" and manipulated to produce a variety of textures and designs. 63/37 solder also makes an excellent solder to bead up the outside rim of copper foiled pieces.
            Lead-Free Solder: Depending on the specific mix of metals, lead free will produce differing liquid, solid, and pasty range temperatures. Check with the solder manufacturers for these specifics. Lead-free solders will perform similar to a 50/50 mix. Lead-free solders require more practice in order to obtain a smooth bead on copper foiled pieces and should not be used on lead came projects. Lead-free solder is the most expensive solder, but is the solder of choice when constructing pieces that will contact food, that will be handled frequently, or that will be used in a child's play area or room.
            • daRk_Kon
              • Apr 2007
              • 109
              also, how is clear flux solder for soldering mobos? like why is it clear flux
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                no clean flux?
                • daRk_Kon
                  • Apr 2007
                  • 109
                  it said clear flux on radio shack... let me find a link.
                  here: http://www.radioshack.com/product/in...entPage=search
                  also
                  that looks good for the person who knows what diameter hole he will be filling for the best alloy and such to use.
                  says i need to use powder type II
                  • daRk_Kon
                    • Apr 2007
                    • 109
                    who uses flux cleaner on the old joint before desoldering?
                    and is this good solder to use on a motherboard for cap remplacement?
                    http://www.hmcelectronics.com/cgi-bi...uct/4800-0004/
                    one more thing, what width braid do you use? .5 or 1.0 or .75?
                    • chth96
                      Is it good to use chemistronic flux off es835b for flux remover?
                      by chth96
                      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                      11-17-2023, 07:25 AM
                    • ahmedtou
                      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                      by ahmedtou
                      help me please
                      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                      I will share all the details with you, including the disc information.
                      Code:
                      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                      Current Profile: BD-R
                      Disc Information:
                      Status: Empty
                      State of Last Session: Empty
                      Erasable: No
                      Free Sectors: 12,219,392
                      Free Space: 25,025,314,816 bytes
                      Free Time: 2715:27:17 (MM:SS:FF)
                      Next
                      08-27-2025, 08:49 AM
                      Multifix 425-01 and 450-01 Rework Flux Datasheet
                      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                      - No Clean Formulations
                      - Low residue
                      - Range of activity to deal with different component solderability
                      - Halide free
                      - Suitable for dispensing
                      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                      Both products are supplied in syringes or cartridges for application by dispensing....
                      10-07-2024, 06:02 AM
                    • evilkitty
                      Flux causing high resistance short?
                      by evilkitty
                      Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                      Temp is on the left humidity is on the right
                      i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                      The pin out looking down from the top is (note this is common cathode)...
                      07-17-2024, 09:38 AM
                    • chth96
                      How can I remove flux with the smallest rubbing?
                      by chth96
                      I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                      Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                      Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                      Is there any way to remove flux with the smallest rubbing or without any rubbing?
                      Any reply would be appreciated.
                      11-24-2023, 05:22 PM
