Rework soldering iron station 852D+
  • tonyuk
    • Feb 2014
    • 238
    • uk
    #41
    Re: Rework soldering iron station 852D+
    Originally posted by tom66
    Fast response can be had by filing an eBay dispute, it gets a lot more priority.
    thanks tom i done that same day so shouldnt take long now
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #42
      dont know what this is like saw it earlier
      http://cpc.farnell.com/1/1/109991-sm...-duratool.html
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        #43
        Don't kid yourself. I'm betting most companies won't send you review samples because they don't view your reviews as significant enough. Until you have a blog 1/10th the size of Dave's, I doubt much free will come your way.
        Otherwise I'd open a blog tomorrow with free samples from Rigol
        a) Please do not use your imagination about how a Business Development Engineer makes decisions?
        b) Please start your blog, you can use it as defense against Rigol poor tactics, when it comes down to "service on warranty" in Europe.
        There is a German guy with poor humor in the Rigol EU mini-castle.
        • tonyuk
          • Feb 2014
          • 238
          • uk
          #44
          so this is there reply same as the other 3 they sent read bellow
          'Dear customer , i have received your ebay message before , If shows SE ,pls make sure all parts connected well first , pls insert the iron handle into the machine first Before send out ,all item pass the check to confirm it works well ,but due to the bump in shipping way ,there may other problem caused if everything is connected well, but still shows S-E, pls check something. 1. use the tweezers and put into the input 2 pins at right side, if the display shows normal. that means the machine is working well. but if it still shows S-E, that means the machine is not working well. it has technical problems. 2. use one wire, pls peel off it and connect the both wire into the input pins. if the display shows normal. that means the machine is working well. AND here is the video to help you how to test it. 1. http://v.youku.com/v_show/id_XNjQwOTQyOTA0.html 2. http://v.youku.com/v_show/id_XNjQwOTQ1MDcy.html Hope for your suppport to solve it ,thanks'
          If you're satisfied with this solution, you can let the seller know by sending a message in the Resolution Centre. If you don't want to accept this offer, we encourage you to send the seller a message with a solution that you'd be happy with.
          • clearchris
            • Dec 2013
            • 687
            Well, did you do what he asked? What were the results?
            • tonyuk
              • Feb 2014
              • 238
              • uk
              #46
              yer i done what video said with wire on 2 pins error went but still waiting for them to send me parts i did fix the hot air part myself it was poor solder joints on the board things is takes them 2 days to reply for each msg and still no parts also should the heater light flash on these ?
              • clearchris
                • Dec 2013
                • 687
                Oh, sounds like you are on your way to resolution.
                Id open up the iron and see if everything is in order. I suspect the thermocouple is broken or out of position. I doubt the heater load is monitored.
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  #48
                  Blue and yellow wires look to be the leads of the sensor.
                  Just a simple continuity test at the soldering iron plug up to PCB, is all that is needed so to make your mind of what is happening.
                  By un-soldering the sensor wires you may measure the sensor resistance, parts exchange will assist if sensor is broken.
                  The guy in this video he used even more words and examples than what they are needed.
                    I don't have to imagine anything. I know they won't send out free stuff. Fine, I'll email Fluke. Maybe they'll send me a new 87-V. That'd be nice. I'd be sure to talk about it on badcaps all I like. Might even mention it on eevblog! And for just the low price of a new 87-V. How can they lose?
                    Yeah... whatever.
                    • Kiriakos GR
                      Banned
                      • May 2012
                      • 940
                      • Greece
                      #50
                      Tom it's Blogger is a different person, different strategy, different profession, different target group, different training, different concept.
                      When others are able to see some value in what you offer, they do respond.
                      • caphair
                        • Nov 2011
                        • 1249
                        #51
                        Anyone experience a problem where the air stops randomly unless turned up to the full setting of 8? Then it’ll either cut out again when lowering the speed or it’ll work fine.
                        Would it be the pump that’s going or dirty potentiometer?
                          • 31218
                          could be anything - put a lamp across the pump and see how it responds
                          • caphair
                            • Nov 2011
                            • 1249
                            #53
                            I measured ac voltage at the air control and it steadily rises from 38vac on lowest setting to 118vac on highest.
                            When it cuts out it measures from 28-34vac on any setting except the highest which kicks the pump back on at 118vac
                              • 31218
                              then it could be the pot, or the chip - i think it uses a 555 timer to drive the triac.
                              my old air station did.
                              • caphair
                                • Nov 2011
                                • 1249
                                #55
                                I connected a 40w bulb (lowest wattage I had) across the motor terminals and it lights but dimly and doesn’t increase in brightness with increasing air speed knob, only when on full air speed does it get brighter.
                                So seems like a controller issue. How would I go about figuring out the problem? Weird that sometimes it works. I tried gently tapping on components when it’s acting up hoping maybe a bad solder joint but it had to affect
                                  07-01-2024, 06:34 AM
                                • shahnld
                                  wds-580 rework station issue
                                  by shahnld
                                  Good day.
                                  i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                  Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                  kind regards...
                                  03-28-2024, 01:14 PM
                                • caprider
                                  Recommendations of quality soldering station and (separate) hot air station
                                  by caprider
                                  Hey,
                                  I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                  I now have a TS100 and some soldering irons and looking for some better tools.
                                  1. Soldering station, budget around 200-240€
                                  JBC BT-2BWA seems to be a good product in the budget.
                                  2. Hot air station, budget around 200€
                                  Up to now I've found ATTEN ST-862D to be a good option....
                                  01-15-2022, 02:05 AM
                                • rmjimenez455@gmail.com
                                  Sumsour station 8586D error H-E
                                  by rmjimenez455@gmail.com
                                  Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                                  09-07-2024, 09:33 AM
                                • mkbehbeh
                                  KSGER C245 Soldering station PSU 220V only?
                                  by mkbehbeh
                                  I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                                  I am...
                                  04-17-2023, 03:11 PM
