30v 10A power supply output cable rating.
  • Fritter
    • Jun 2023
    • 21
    • England
    Hi
    I’m looking at a cheap 30v 10amp max bench supply. Would the banana plugs, wires and a barrel connector (for laptop fittings) have to be rated at 10 amps ? It’s unlikely I’d see more than 5, but your thoughts would be appreciated.
    thanks.
    • 31087
    if you had 10a cable it wouldnt fit in the barrel plug.
    get good 4mm jacks though - you dont want them heating up.
    go look at rapid for good range of test leads / plugs
    https://www.rapidonline.com/4mm-single-pole-connectors
    • shadow666
      How can i connect type c cable to 19v power supply
      by shadow666
      hello
      i have a power supply adjustment like image
      i want turn on asus vivobook with type c charger
      i want a connect type c cable to power supply adjustment but type c cable have 3 wire and i don,t know how to connect the cable type c to power supply adjustment
      please help me to let me know
      sorry English is not my first language...
      12-23-2023, 03:32 AM
    • vladimir1909
      How to attach a type C cable to a DC power supply
      by vladimir1909
      Hi
      Maybe somebody knows how could I attach a type C cable to a DC power supply for troubleshooting a macbook.
      I have peeled the cable and and hooked the ground to ground and V+ to V+, but when I trie to charge a macbook it doesnt work.
      I have seen an adapter, but first i would like to try and build my adapter by myself
      Sorry for my english
      PD: I have attached pictures of the adapter and the power supply Im using...
      11-23-2024, 05:46 PM
      03-31-2024, 02:12 PM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • Bonaventure Vigil
      What cable to connect from Power Supply Regulator
      by Bonaventure Vigil
      I'm still newbie and want to start up the shop for motherboard repairing. Need help what cable to connect from psu variable or regulator to any motherboard that we repairing? Any cable names? Since i already order the power supply regulator. From that, i can check the current and voltage go inside motherboard.
      10-01-2024, 01:47 AM
