about ring tester usage
  • senz_90
    • Aug 2013
    • 328
    • Indonesia
    is there anyone know where i could find the manuals of ring tester? i have googling but it just give me an explanation from Mr Jestine Yong and Anatek Corp. really appreciated it and many thanks.
    i just didn't have experience using this tester and i feel that explanation not enough for me.. just my IMO.
    i built this tester based on Mr Humphrey site, so i just wanna know the way to test it on primary and secondary by practicing pict. i means just not a theory that's haven't a picture to see that... anyone have the manuals? or please if dont mind give me example pic to test transformer especially smps atx power supply.
    wew. sorry for double post. my internet connection just poor and i don't know that is post already..
    "There is no shortcut to be successful. No pain, no gain."
    Best Regards
    Rudi
    Thank You
  • fpliuzzi
    • Nov 2012
    • 15
    Re: about ring tester usage
    The original "LOPT/FBT Tester" manual can be found at...
    The newer "Blue Ring Tester" manual is at...
    https://cdn.badcaps-static.com/pdfs/...93bffb49ea.pdf
    Hope this helps,
    Frank
    • senz_90
      • Aug 2013
      • 328
      • Indonesia
      Hope this helps,
      Frank
      thanks . i have download it and read it. i have trying to test small inductor on secondary section my atx power supply and it appears no led lit.. on the manuals said that if no led lit there is a short but the atx power supply fine for the voltage rails.. so i am just confuse. what is the limited from that device.. maybe the other's have an experience using that and please give a advice to using that properly..??
      Best Regards
      Rudi
      Thank You
      • fpliuzzi
        • Nov 2012
        • 15
        I'm not quite sure if you saw this article by Justine Yong...
        http://www.electronicrepairguide.com...terresult.html
        In it Justine states the following...
        "What this tester can't do:
        Generally the higher the inductance value the more LED from the tester will light up, assuming if there is no shorted turn in the winding. In other words it can be used to check on coils that have at least .3milihenry and above. If the value is lower than that then there will be less LED will light up and sometimes the LED may go off too. Usually the smaller the coil, the smaller will be the inductance value. Below are the components that this tester can't test:
        1) It can't be used to check on small coils and ferrite bead because the inductance value is too small.
        2) It can't be used to check on vertical winding in CRT Monitors/Tvs because the vertical winding is usually too low Q to respond to any ring tester.
        3) It can't be used to check on secondary winding of Switch mode and Flyback Transformer in CRT Monitors/Tvs because the inductance value is too small."
        Maybe the small inductor that you are trying to test with the Blue Ring Tester has an inductance value that is too low for the tester to give a valid reading.
        Also, this short video by Anatek Corp may be of interest to you if you have not seen it...
        http://www.youtube.com/watch?v=CFyRO42JMbE
        Frank
        • senz_90
          • Aug 2013
          • 328
          • Indonesia
          "What this tester can’t do:
          Generally the higher the inductance value the more LED from the tester will light up, assuming if there is no shorted turn in the winding. In other words it can be used to check on coils that have at least .3milihenry and above. If the value is lower than that then there will be less LED will light up and sometimes the LED may go off too. Usually the smaller the coil, the smaller will be the inductance value. Below are the components that this tester can’t test:
          1) It can’t be used to check on small coils and ferrite bead because the inductance value is too small.
          2) It can’t be used to check on vertical winding in CRT Monitors/Tvs because the vertical winding is usually too low Q to respond to any ring tester.
          3) It can’t be used to check on secondary winding of Switch mode and Flyback Transformer in CRT Monitors/Tvs because the inductance value is too small."
          Frank
          ok. i got it. so it has a limitation on inductor. maybe the one i have tested has a low value.. what about CT (centre tap) transformer? where is the legs that i have to touch with my probe?
          this is just likes a funny question, but you know that the explanation so limited i think, because that is many design on smps transformer for example.. sometimes i look the transformer at atx power supply have a 4 and 3 legs on primary sometimes just 2 legs. so i am confused. maybe it takes your time for explaining and i am really appreciated it.
          i know secondary could measure when i googling but i forgot the link.. it shows that we must shorten the secondary when the tester across primary and if the led just dim all, it means our secondary good.. if led just lit all means that secondary failed. and the secondary have a many legs on smps transformer and which one to be shorten?? in cellphone charger i have tested it and it rights because just have a 2 legs on secondary. maybe i have to found the datasheet for transformer before test it with the tester?
          Best Regards
          Rudi
          Thank You
          • tony359
            Ring tester
            by tony359
            I'd like to add a ring tester to my toolbox to test flybacks but also low frequency transformers if possible.
            I found a few products online, some based on the "diodegonewild" design, others are different designs. Some are available to build DIY, others are not.
            Any suggestions on a DIY one I could put together? Ideally something which would also be able to test low frequency transformers, that might be handy.
            So far I found these two:
            http://bobparker.net.au/Basic%20Digital%20Ringer/ (the posher version...
            09-13-2023, 07:34 AM
            Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
            I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
            One other check that...
            08-03-2021, 06:41 PM
          • CapLeaker
            VOIP, ATA REN and old analog phones ring voltage booster
            by CapLeaker
            I am working on a backup phone to VHF paging solution. Basically I am dealing with the old Zetron pagers. Here is how it works: One calls a number, the Zetron picks up, operator punches in the DTMF access code, the Zetron keys the transmitter and you can talk. press # the Zetron unkeys the transmitter and hangs up / times out.
            Now this setup works good on the old land lines, but not at all using a VOIP ATA. You can call all you want and swear like a bastard at the Zetron, but it will not (even if I threaten it's life) pick up.
            Yep, I know about the high ring voltage...
            12-10-2022, 09:27 PM
          • Lifeisfun
            Trying to troubleshoot DDR4 SODIMM slot with slot tester
            by Lifeisfun
            Hi folks!
            I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
            Eventually I discovered that it was related to moving the laptop.
            Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
            If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
            I removed the board got one of those memory slot testers...
            06-04-2025, 02:26 PM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
