My new (used) Fluke 77 Series IV DMM
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: My new (used) Fluke 77 Series IV DMM
    Originally posted by retiredcaps
    Use a 3.000V DC source for calibration. I find that the green pin on some ATX power supplies is close to 3.000V. Have the other calibrated meter plugged in at the same time so both read the same value.
    See my example of calibrating a Fluke 77 II
    http://www.eevblog.com/forum/general...254/#msg152254
    Good news for me. I was able to take my Fluke 77 to work and compare it to the calibrated Fluke 179 and it was the same readings on both. I used a 1.5V battery so I was getting readings down to mV on the comparison then I used a 9V battery afterwards. I used my 77 to calibrate my 21 and it seems to be good now. I was also able to get the peak hold mod done while I was calibrating it and that also seems to work.
    I have purchased 3 used 20+ year old Fluke 70 series style multimeters and all have been within spec (0.3% + 1 digit) in the DCV range. The 77 II that I cleaned up with was the "worst" at 4mV off, but still within specifications.
    If your Fluke 21 is the one that is off, that is the worst drift I have personally seen in an older Fluke.
    I did buy this meter used so someone else may have messed with the calibration or I may have messed with it myself so long ago that I do not remember it. It would not be the first time I have messed with something that I had no idea what it was supposed to do just to see if I could figure it out. This is a habit I still seem to have from time to time.
    • retiredcaps
      • Apr 2010
      • 9271
      Excellent job on the DC V calibration and auto hold modification.
      PS. The 3.000V DCV calibration recommendation comes directly from the Fluke service manual.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        BTW, the old 70 series multimeters will run up to 2,000 hours on a 9V battery.
        So I put new batteries into my smoke detectors annually and use the old ones inside my multimeters.
        The Fluke 77 IV/179 runs up to 400 hours on a 9V (assuming no backlight).
        • retiredcaps
          • Apr 2010
          • 9271
          @LDSisHere, I can't tell from your first photo, but I recently bought an used Fluke 77 IV and ran into something similar to what ModemHead posted at
          http://mrmodemhead.com/blog/fluke-77...per-corrosion/
          You might want to check yours when you have a moment? To lift the pcb off the case, you have to remove the 440ma fuse to expose a screw underneath.
          Hopefully, your pcb will be clean and pristine.
          • LDSisHere
            • May 2012
            • 727
            • U.S.A.
            Thanks for pointing this out. After reading this post I tore into my meter at the first opportunity. There were two places on the back that had just a slight bit of "snow" and around the LED's there was just a trace amount that I could barely see. A Q-tip and 91% alcohol made quick work of the problem areas. I think I will check the board every time I have to change the battery at the minimum.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              I had the same problem areas around the LEDs.
              • modemhead
                Lurking
                • 52
                I don't know why, but the backlight LEDs and the area around the piezo beeper seems to be a magnet for that white stuff.
                • spectrum
                  • Oct 2013
                  • 5
                  • Italy
                  #28
                  Hi, I am writing from Italy. I had this multimeter 77IV (circuit board Fluke 17X) which does not work. In the display I can see only this sign "- - - -", no numbers. I see right all the measuring selection (VDC, VAC, mV ecc..), I can read "LEAD" when I am in the A selection, and at the start I can read 77-IV.
                  Someone knows which is the problem ? What are the components failed ?
                  Ciao. Stefano
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    Back in post #24, I provided a link to modemhead's blog entry and it may provide a clue ...
                    "The meter was non-functional with some digital-domain fault that caused it to always display “- – - -”. The trouble turned out to be a corroded via that was open from the top layer to the bottom, due to the plated-through hole being eroded away. A wire patch soldered in brought the 177 back to life."
                    PS. As my sig file suggests, clear focused pictures following my instructions exactly help us help you.
                    • spectrum
                      • Oct 2013
                      • 5
                      • Italy
                      #30
                      Thanks Retiredcaps, it is useful but I do not find corrosion in my Fluke, anyway I will check better.
                      • Kiriakos GR
                        Banned
                        • May 2012
                        • 940
                        • Greece
                        #31
                        There is nothing to find .. get another multimeter and do measurements so to confirm that all PCB lines are in good condition.
                        • spectrum
                          • Oct 2013
                          • 5
                          • Italy
                          #32
                          No sign of corrosion, PCB in very good condition, PCB lines I checked OK
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            I know you are discussing this over at modemhead's blog and that he is travelling right now.
                            Let me ask some questions.
                            1. Are you the original owner?
                            2. How did this --- problem start?
                            3. Was the meter subjected to high voltage or high current?
                            4. Did this meter work properly before?
                            5. Has this meter been dropped?
                            6. Is there any battery corrosion?
                            • spectrum
                              • Oct 2013
                              • 5
                              • Italy
                              #34
                              Thank you for the interest. Here the answers:
                              1) It was a multimeter that my company bought and used for some years
                              2) I do not know, it is happened not in my hands.
                              3) I think no, we do not have high voltage or current in our labs (but I cannot guarantee)
                              4) I think yes, I remember so.
                              5) I do not know but it has no damage and it is in very good condition
                              6) No sign of some corrosion, PCB clean and in very good condition.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Since the Fluke 77 IV is a current model, the lifetime warranty should apply if your company bought it from an authorized dealer and assuming the meter wasn't abused.
                                I would contact Fluke and explain the situation.
                                • Kiriakos GR
                                  Banned
                                  • May 2012
                                  • 940
                                  • Greece
                                  #36
                                  Fluke life time warranty were set at 7 years period before 2 years ago, and then some how they readjusted it again with a lower time period than that, so to support with those funds the R&D about new products.
                                  I have stop following this confusing subject for some time.
                                  They should make one chart with their product range and the warranty period for its one.
                                  Or else every one who spend 40$ for Fluke 101 he will believe that he gets seven years warranty with it.
                                  • spectrum
                                    • Oct 2013
                                    • 5
                                    • Italy
                                    #37
                                    Here in Italy the Fluke service is not so sure.
                                    Some co-workers tell me that they were charged for warranty repair and I can confirm this. I sent this meter and it has been returned with an estimate repair of 120-130 euro. I think this warranty lifetime seems a fake. anyway out of any convenience (a new 175 costs 199 euro).
                                    We asked to Netherland Fluke if is there another service in Italy but no answers. In our company we are considering to buy Fluke no longer.
                                      Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                      by sam_sam_sam
                                      I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                      I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                      12-31-2023, 06:04 AM
                                    • Baldbentley
                                      repairing a Fluke 335 clamp meter
                                      by Baldbentley
                                      I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
                                      Thanks...
                                      10-18-2023, 02:05 AM
                                    • chth96
                                      Is it possible to test small ceramic disc capacitor with analogue meter?
                                      by chth96
                                      I read EBOOK of Testing Electronic Component and found that
                                      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                      Is it really possible to test small ceramic disc capacitor with analogue...
                                      03-09-2024, 10:03 PM
                                    • jorpec
                                      Changing the scale of an analog meter
                                      by jorpec
                                      Hi
                                      I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                      I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                      Thnaks
                                      01-23-2023, 10:37 AM
                                      How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                      by sam_sam_sam
                                      About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                      Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                      12-14-2023, 07:45 PM
