Desoldering?
  • MD Willington
    • Sep 2004
    • 702
    I like the ghetto solder sucker there...I suppose a shopvac could be rigged up to do the same, the only thing is that moving a lot of air across the heated area will cool it down pretty quick.
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • mcel
      • Mar 2005
      Whatever you do, don't use a drill to clear out holes, even if you think it's smaller. These are multilayer boards with internal planes, for at least ground and +V, in addition to the tracks you can see on each side. The holes are plated through and arranged to make contact where necessary with the internal tracks. Drilling could destroy these connections.
      Mike
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i watched an idiot drill solder out of a board with an isotip pc drill attachment.
        warned him that if the slightest bit off center he would damage the throughholes.he did it anyway rather than having me take the board home and doing it right.
        after his "repair" the board had several new problems.
        took me 5 hours of rework to fix that mess.
        he had spun out the throughholes in 9 places and soldered heavy enough to hide them.
        customer fired the idiot on the spot when i told the boss what their resident "tech" had done.
        mitsubishi wanted 3k for that board.
        and they had payed 9k for the machine(wire edm) knowing it had issues.
        Mike
        • stretch0069
          Screwed Up Super Moderator
          • Oct 2003
          • 2658
          • oooo ess aaaaaaaaa
          Someone PM'd me about drilling out the holes. I said it was a bad idea. He/she did it anyway (I guess) and tried converting me to drilling as well! Oh well. Some people.
          I realize that not everyone has access to a good soldering/desoldering station or the money to buy one, but I have access to an old (at least 10 years) Pace PPS-200C. So far I've replaced two sets of caps and a ZIF socket. It worked awesome. No problems getting the holes clear. If only I had one two years ago.
          Yes....I said ZIF. Ok....I was bored and didn't have anything new to calculate (see 'ton of caps' )
          "Its all about the boom....."
          Guns kill people like spoons made Rosie O'Donnell fat.
          We now return you to your regularly scheduled drinking.
          "Fear accompanies the possibility of death.....calm shepherds its certainty"
          Originally posted by Topcat
          AWD is just training wheels for RWD.
          • mcel
            • Mar 2005
            Back in my mainframe computer development days, hundreds of years ago, we were pretty proud we'd reached a 12 layer central processor backplane. But I see manufacturers now talk of 20 or more layers... Now on that sort of board, you really don't want to mess with the plated thru holes!
            • ncdave
              • Oct 2003
              • 33
              Re: moby solder sucker
              Originally posted by ncdave
              I need an SPDT "Y-valve" rather than a simple SPST on/off valve, so that I can switch the tip back and forth between atmosphere and vacuum, but I can't seem to find such a valve. :-( Does anyone know where I could get one?
              I've learned that they are called L-type 3-way ball valves. They may also be called multiport valves, diverter valves, or selecting valves.
              Brass & stainless L-type 3-way valves can be bought on eBay starting at about $10.
              Here's a company which sells many types of plastic 3-way ball valves:
              http://www.usplastic.com/catalog/def...arentcatid=870
              Note that some of them are spec'd as "not for vacuum." I'm no expert, but I suspect that, in general, ball valves are probably better for controlling pressurized fluids than for controlling vacuum, because the pressure presses the ball against the port, to help make a tight seal. This might be particularly true with "floating ball" designs. However, I think one of these would probably work well for the Moby Solder Sucker.
              If I understand correctly, there are two broad categories of 3-way ball valves:
              L-type are "break-before-make." For this application, that's what we'd want.
              T-type are "make-before-break."
              Wikipedia, though worse than useless for anything even slightly controversial, has some good info on this, here:
              https://en.wikipedia.org/wiki/Ball_valve#Multiport
              Here's a diagram, from a valve manufacturer on Alibaba:
              And here's the Moby Solder Sucker, needing one of those valves:
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • jm1234
                Solder joints on heat sinks matter?
                by jm1234
                solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
                I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
                04-28-2024, 04:38 AM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • valvashon
                Repair Success! Middle Atlantic UPS2200R-IP
                by valvashon
                Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                02-06-2024, 12:54 PM
                Multifix 425-01 and 450-01 Rework Flux Datasheet
                REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                - No Clean Formulations
                - Low residue
                - Range of activity to deal with different component solderability
                - Halide free
                - Suitable for dispensing
                - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                Both products are supplied in syringes or cartridges for application by dispensing....
                10-07-2024, 06:02 AM
