poor mans reballing
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    poor mans reballing
    so, with the advent of me getting a heatgun, I decided to try my hand in reballing, as one time I saw a video online of how it can be done without actual balls, stencils, or anything but a heat gun, iron, braid, and lots and lots of paitence...and a careful hand. I have tons of nforce 3/4/6 boards with bad balls, and this is what I tried, they all failed, but I learned several things
    the old solder has some nasty black shit in it when I braid it off, on all of them. The trick I'm going for is to braid the solder off the board pads and the chip pads, then flux-up the pads, get a tiny dab of solder on each (board pads and chip pads). put the chip back and re-heat it up, try to get them to merge. Mind you these are not balls, but dabs, which is why both of them need a dab, and it will put the chip actually right against the board, and make a small, flat soldered connection. not sure about the heat implications here, with the chip being right up against the board, are we getting a higher chance of getting disconnected pads, even with flux and leaded solder? not sure
    first thing I did was a nforce 2 southbridge, came out REAL easily, popped a pad with the iron trying to braid the old solder off. I turned it up, and actually wetted the tip from then on out, this let the old solder flow more easily into the braid, without putting stress on any of the pads. After destroying the balls on both the chip and board, I realize from there on out, putting 92% isoprobyl on my finger and just rubbing the damn pads gets rid of this black shit left over, I tried q-tips at first with VERY bad results (q-tip hair stuck around pad, tore them off). Then I tried the northbridge, came off pretty easily, still learning. I put the heat gun on high (dual mode gun). Tried to melt some more of the solder on the board pads cause some of it will still dull and well, bad, ended up putting it too long on the board, and warped it, a common problem
    tried then an nforce 4 board nb. Tried heatgun on high, old solder was so crappy the chip still did not come off, and when I finally go it hot enough, not only was some pads ripped when I got the chip off, but there was a panny next to one of the pads that bloated, hissed, and burned, right infront of my eyes, which was pretty cool
    Next was a nforce 6 board, tried the gun on low setting, REALLY close, and eventually I got the chip off without tearing any pads.
    after you braid the old solder off, clean the pads on both the chip and board, what you do is flux an entire area, put a bunch of solder on the tip, and run the solder 'bubble' moved to the bottom of the tip by our friend mr. gravity over the pads, and it pools on each pad. if you do not use flux, it just spreads across multiple pads, but can be re-cleaned and re-applied with flux
    I did another nforce 4 board after this, an old A8N-E, the chip was so stubbron, it would hardly move till I put the gun on high, and got it RIGHT UP to the damn chip. Smelled something burning, which is expected, then I realized the power clip connector next to the northbridge melted like cheeze, and I got laughed so hard, I still don't know why
    in the end, I realized I need a magnifier, I was doing this with my super perfect vision, but I could easily still miss a pad, which might nullify the whole thing
    I need a flux pen, not a syringe, and i'm starting to think about using an auyoe, but I don't have the $100 right now
    in addition, I used no protection for the rest of the board, and am thinking about doing the foil thing, still not sure what that spells for the pico caps on the top of the nf 6 chips
    any ideas? I want to eventually do this for hp dvs and other nvidia plagued products
  • retiredcaps
    • Apr 2010
    • 9271
    Re: poor mans reballing
    For my one and only heatgun reflow, I used aluminum foil to protect the areas around the nvidia chip. I also thought about using an aluminum pop can cut out in the shape of the nvidia chip?
    I have seen other people use kapton tape when using a hot air station to protect the surrounding components.
    http://www.ebay.com/sch/?_kw=kapton%20tape
    http://www.youtube.com/watch?v=ePp6YagHElc
    --- begin sig file ---
    --- end sig file ---
    • brethin
      • Dec 2008
      • 1907
      Reballing without using stencils and balls isn't reballing. What you are doing would be closer to reflowing but with a twist where by you are going to do nothing but make a mess. If by a stroke of luck and you did manage to get one to work doing this it will not last as long as a proper reflow would so why go through all the extra steps.
      • godin
        • Dec 2011
        • 34
        I would be inclined to agree, your chances of success are infinitely higher by just reflowing if you don't have the equipment to reball. Use a good flux, make sure you get hot enough to melt all the solder and keep it liquidous for a time. It is difficult to get it right using the proper equipment, you may get some to work for a while. Good luck
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          hm. well at least I can get it off (most of the time, might use foil to try). get it cleaned up. After that, it seems its just getting the balls, stencils, chip holder, and it shouldent be a problem
          maybe I should get an auyoe, but errg $100 is a lot of money next to the lack of money I have
          • Agent24
            I see dead caps
            • Oct 2007
            • 4953
            • New Zealand
            Yeah, You NEED stencils and proper balls if you want to do it properly and have a chance of it actually working. Soon as you go about just sticking dabs of solder on they end up different sizes, which is going to create a big problem when you solder it back onto the PCB.
            That's for starters. I don't think I'd be game enough to even try it with a heat gun. A proper IR BGA rework station is what you should use.
            -David VanHorn
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              you want to lend me 7 grand?
              I think in most cases, and air bga rework station (auyoe) would be ok, yeah a heat gun might be a problem
              • uberplasma
                • Oct 2011
                • 85
                I saw some little reballing "stations" on ebay that came with like 100 stencils, little hand held screen holder, and balls and flux for like 39 bucks and free shipping from china, I am going to order it and see how good it is, figure if it works once or twice it has paid for itself
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  Got me thinking, I remember seeing a video on Youtube of someone using a heat gun in some kind of jig to remove a big BGA: http://www.youtube.com/watch?v=F3B83e0gp4Q
                  Doesn't show the setup in detail but it certainly looks like it works, he's got a thermocouple there but looks like just for readout and not controlling anything.
                  There may be some kind of grille etc inside that square pipe to reduce airflow and\or make the heating\airflow more uniform etc. No idea if it's necessary but I notice that some BGA nozzles sold for SMD Rework stations have a grille in them: http://www.ebay.com/itm/BGA-Nozzle-2...-/260913745008
                  Also, there's this: http://www.youtube.com/watch?v=ZrWRToFImbk (Stand which should work with majority of hot air rework stations)
                  But this one: http://www.youtube.com/watch?v=38IaWi7Y-Nw seems to use a hotplate for bottom heating\preheating. I have noticed the 'proper' BGA rework stations also have a bottom heater, so might be worth looking into. I think for anything this major you should probably do preheating etc.
                  -David VanHorn
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • dbuergi
                    Restore solder pads for SMC on MacBook A1466
                    by dbuergi
                    i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
                    Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
                    As written i want to improve skills so it doesnt matter if it takes longer.
                    12-29-2024, 10:24 AM
                  • corrize
                    Best way to solder LVDS connector for beginner (and qfn) ?
                    by corrize
                    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                    See the test :
                    https://youtu.be/bNAzC-EvqHs?t=1767
                    With hot air from bellow the board, that's...
                    03-09-2023, 02:57 AM
                  • Srdjan01
                    IPhone 12 ProMax - Thoughts of (not so young) apprentice
                    by Srdjan01
                    Hi guys.
                    I'm working on my first board reballing.
                    It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
                    Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
                    I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...
                    03-17-2025, 02:49 AM
                  • DynaxSC
                    Each GPU reballing produces different MATS results, looking for root cause ?
                    by DynaxSC
                    I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
                    1. When I received the card Mats showed one memory with errors.
                    2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
                    3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
                    4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
                    5. Made...
                    12-11-2024, 07:44 PM
