Metcal MX-DS1 desoldering handpiece "shop air"?
  • proci
    • Oct 2011
    • 5
    I've just bought this desoldering gun for my MX-500 system,and the PDF says it requires "shop air" to desolder with it.I am hungarian and my dictionary has no result to "shop air" so I dont know what it means... Does it mean compressed air? Or I need a vacuum pump to normally work with it?
    Thanks for helping!
  • mariushm
    • May 2011
    • 3799
    Re: Metcal MX-DS1 desoldering handpiece "shop air"?
    It means that the device does not have a pump to suck air, it relies on you having a separate device already in the store.
    • proci
      • Oct 2011
      • 5
      Yes I know that it it needs an external device.(Only the SP440 series has built in pump)But my question is vacuum pump or air compressor?
      • Krankshaft
        • Jan 2007
        • 2328
        Yes shop air means compressed air.
        Depending on amount of air it draws (measured in Cubic feet in the US) you may need a sizable compressor pump and tank to keep a constant steady vacuum at the tip.
        It probably relies on the same principle that a compressed air vacuum does.
        • Evil Lurker
          Warranty Voider
          • Feb 2011
          • 454
          Both.
          Im guessing it uses a venturi style pump.
          • proci
            • Oct 2011
            • 5
            Thank you for the answers guys! I've found the own manual of the MX-DS1 and it recommends 80PSI which is about 5,5 Bar.I've tried it with a refrigerator compressor and its worked fine.The only thing left now is to find an air supply with 5,5 Bar adjustable pressure
              ZD desoldering station pump rebuild
              by stj
              just did one.
              works great.
              so here's the discoveries.
              the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
              the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
              so you need to clean everything to get rid of all the tacky black stuff.
              then reassemble it.
              *BUT*
              you must put the 2 screws into the assembly only finger-tight.
              if you tighten it properly the valves dont work....
              08-21-2024, 05:59 PM
              ZD-915 vacuum pump motor mount service alert
              If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
              One note this unit has been repaired already once because of switching power supply regulator ic chip failure
              Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
              The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
              09-19-2021, 02:15 AM
            • hans_meier
              HP EliteBook 840 G6 how to dump without desoldering
              by hans_meier
              I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
              01-04-2025, 04:11 PM
            • Dreigas
              ISL95880HRTZ desoldering temperature
              by Dreigas
              I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
              Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
              09-13-2024, 10:59 PM
            • armini
              18VDC PSU completely dead - ZD-915 desoldering station
              by armini
              Hi everyone!
              Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
              Due to a lack of time, I set it aside and didn't look at it.
              Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
              According to replies in 18VDC PSU has dropped to...
              04-25-2023, 07:49 AM
