A soldering question.
  • craftech
    • Mar 2006
    • 45
    The last time I did this I used a desoldering iron like this one:
    http://www.radioshack.com/product/in...entPage=search
    I never thought of the dental tool or toothpick method.
    My question is this:
    Given that the dental tool method works really well, why use the solder sucker at all? Why not simply heat the leads....remove the capacitors....stick the dental tool in there after reheating.......remove the dental tool.....stick the new capacitors in..........reheat the old solder to fasten them adding more if you need it?
    John
  • craftech
    • Mar 2006
    • 45
    Re: A soldering question.
    Tried the toothpick method mentioned in another thread. Bad idea. Tip broke off inside the via and it was a bitch to remove the pieces before I could solder. Stick to the dental tool or stainless steel equivalent.
    Didn't use the desoldering tool at all. Worked great.
    Next time I want to try a can of compressed air from the component side to clean out the holes just for the heck of it.
    John
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      John
      If there is a VIA in that hole you can say goodbye to that VIA...
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i doubt it will kill the via...but the "canned air"in most places is r134a.its flammable!
        could be unpleasant at the least to get a ball of fire in the face.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          i got a can here, non-flammable it says on the can
          still dumb ideas.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            msds says : dimethyl ether 5-10%, tetrafluoroethane 60-100%
            7.5 % by mass of the contents are flammable
            Do not spray on a naked flame or incandescent material.
            http://servisol.co.uk/wwwcrc/msds/UK20026-3.htm
            hmmm think i need a antistatic vacuum. doesnt sound good to breathe
            • tiresias
              • Feb 2006
              • 489
              Hi Will,
              Tetrafluoroethane is not going to easily burn or react with much (aside from extremely reactive agents such as fluorine or the deadly ozone), so that won't realistically be a fire risk of any kind.
              Me2O, on the other hand, is a readily flammable gas, so I'm surprised they've added it there, even in small quantities, since there are safer substitutes one could use.
              Neither of those two is particularly toxic, however, so you won't have to worry about that... at least, unless you're breathing them very concentrated - then they would have a inhalant anesthetic-like effect.
              The can I have here is 100% chlorodifluoromethane, which is non-flammable and nontoxic. Any damage to the ozone layer from a 400cc can is to be considered 'collateral'.
              • craftech
                • Mar 2006
                • 45
                The cans I have say Difluroethane and 100% Ozone safe and Non-flammable. I don't see why this relatively low pressure can of air shouldn't work to blow out a hole. What's going to happen?
                • rex98
                  HP DMI Tool
                  by rex98
                  HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                  DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                  The DMI Tool given here are for personal use only.
                  DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                  You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                  from it, and that you please credit the author...
                  07-02-2025, 05:51 AM
                • salim5566
                  loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                  by salim5566
                  Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                  06-26-2025, 03:25 PM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • corrize
                  How to find smd badcap onboard ? (Tool, method)
                  by corrize
                  Hello, if 5 capacitors are in parallel, and one of them is shorted, how to find the shorted one without disolder anything ? And except courant injection.
                  It's seems not possible but maybe there is trick or tool working ?
                  Ultra low resistance meter ? Maybe with heat ? If cap is shorted, it become conductor, so conductor of heat too. And maybe a heating element at a side of cap and thermalmeter at other side and mesure time for reach a valor ?
                  So have you seen or tested such tool or method pls ?
                  06-08-2021, 06:46 AM
                • Ady2017
                  SMD fuse soldering advice please
                  by Ady2017
                  Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                  11-07-2025, 12:03 PM
