How to find smd badcap onboard ? (Tool, method)
  • corrize
    • Apr 2021
    • 268
    • France
    Hello, if 5 capacitors are in parallel, and one of them is shorted, how to find the shorted one without disolder anything ? And except courant injection.
    It's seems not possible but maybe there is trick or tool working ?
    Ultra low resistance meter ? Maybe with heat ? If cap is shorted, it become conductor, so conductor of heat too. And maybe a heating element at a side of cap and thermalmeter at other side and mesure time for reach a valor ?
    So have you seen or tested such tool or method pls ?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: How to find smd badcap onboard ? (Tool, method)
    Something like this https://www.badcaps.net/forum/showthread.php?t=93031 a sensitive low ohm meter.
    • corrize
      • Apr 2021
      • 268
      • France
      Yees, and someone use it ? It is usefull in practice ? I saw ESR-100 sold on shops, it's a same ?
        • 30931
        no, esr-100 is for capacitors testing off-board.
        not for finding shorts
