How to find smd badcap onboard ? (Tool, method)
  • corrize
    • Apr 2021
    • 294
    • France
    Hello, if 5 capacitors are in parallel, and one of them is shorted, how to find the shorted one without disolder anything ? And except courant injection.
    It's seems not possible but maybe there is trick or tool working ?
    Ultra low resistance meter ? Maybe with heat ? If cap is shorted, it become conductor, so conductor of heat too. And maybe a heating element at a side of cap and thermalmeter at other side and mesure time for reach a valor ?
    So have you seen or tested such tool or method pls ?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: How to find smd badcap onboard ? (Tool, method)
    Something like this https://www.badcaps.net/forum/showthread.php?t=93031 a sensitive low ohm meter.
    • corrize
      • Apr 2021
      • 294
      • France
      Yees, and someone use it ? It is usefull in practice ? I saw ESR-100 sold on shops, it's a same ?
        • 31247
        no, esr-100 is for capacitors testing off-board.
        not for finding shorts
        • rex98
          HP DMI Tool
          by rex98
          HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
          DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
          The DMI Tool given here are for personal use only.
          DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
          You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
          from it, and that you please credit the author...
          07-02-2025, 05:51 AM
          by Vesko356
          08-11-2023, 03:27 AM
        • ferah831208
          help with bios decompose for Asus s5506ma
          by ferah831208
          I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
          08-24-2025, 05:35 PM
        • danielgerman681
          ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
          by danielgerman681
          Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
          08-27-2025, 01:17 PM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
