CCFL Tester
  • killian6pk
    • Apr 2010
    • 502
    CCFL Tester
    Is there a set of instructions for building a CCFL Tester? I'm thinking of something to plug a set of lights (2) pulled from a monitor to check to see if they are working.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • jsog
    • Feb 2011
    • 220
    Re: CCFL Tester
    Some people have adapted CCFL computer case light power supplies for that. They're cheap: http://www.newegg.com/Product/Produc...82E16800888071
    A monitor with a broken panel works okay. lcdparts.net has adapter and extension cables.
    • Joun
      • Jul 2011
      • 191
      • Greece
      Re: CCFL Tester
      You can also try this: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
      • gerg
        • Nov 2010
        • 278
        Re: CCFL Tester
        Iuse the CCFL computer case light power supply and it works perfect and like jsog said it's cheap which i like
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
