Micrometer??
  • PlainBill
    • Feb 2009
    • 7034
    Micrometer??
    An interesting ad. http://phoenix.craigslist.org/nph/ele/2321162995.html
    Just when I thought I'd seen it all, something new comes along.
    PlainBill
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Micrometer??
    Oh, you mean a micrometer! Why soitenly...
    Good ol' dregslist/creepslist...
    "miscategorized?"
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Micrometer??
      Looks like the Meterman 15XP that I got from ebay for 99 cents.
      --- begin sig file ---
      --- end sig file ---
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Micrometer??
        I don't think that measures down to 'micros', just 'millis'.
        They should call it a millimeter.
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Micrometer??
          Which I suppose would make it metric? ???
          - Dr Seuss
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: Micrometer??
            Hmm, Micro (µM) is 0.001 millimeter (mm)
            In everyday talk a thousandth of a millimeter, well, everyday talk outside of the US that is
            But maybe you are right, it might just have two decimals...
            I don't know whats more sad, this incorrect ad for a multimeter or the fact that I almost got annoyed with kaboom posting a picture of a Micrometer since it just takes the all too obvious (in my world) and over does it
            • zzpkcq@gmail.com
              Confused - I don’t want to order wrong thing
              by zzpkcq@gmail.com
              Going to replace op-amps in a guitar amp jcr072d
              so TI versions have suffix D IP etc. There didn’t seem to be an explanation of these anywhere. I think they indicate the physical pin characteristics but what do they represent- anyone have a list....
              05-29-2024, 03:06 PM
            • Maximasraine
              Confused why a capacitor would read OL
              by Maximasraine
              I'm working on--really just learning how to repair--an Acer Chromebook that no longer works. As far as what is wrong with it, when you plug in the charger, the light on said charger goes out. The first thing I did, then, was check the power rails for a short, which seems to be the main culprit in many instances, but not in this one. No shorts, but I did find something that confuses me. From the attachment, you can see that I circled a capacitor. The reason I circled it was that it reads "OL" (In resistance mode). I changed it, but the issue persists. This is the opposite of a short,...
              03-03-2024, 06:48 AM
            • mitsu2k
              Confused when it comes to "I" and "1" when it comes to SMD marking codes
              by mitsu2k
              Hello folks, I seem to have a lot of trouble when it comes to distinguishing markings on SMD components especially when it comes to the question of whether it is a 1 or an I. for example, I see components marked NI. It looks just like that. However, I cannot tell if that "I" might be a number one instead. Is there a rule of thumb that manufacturers use when using these characters? Attached is an example. This is just one example out of many I come across but it's a good illustration of my point. I appreciate any input....
              12-28-2023, 11:08 PM
            • budwich
              Headphone wires.... confused!
              by budwich
              I picked up a "beat up" set of sennheiser headphones (hd201). The phono plug end seemed to have an issue such that most of the time only one ear would work but by compressing / bending the jacket of the phono plug, I could cause the other ear to work. Must be a phono jack (3 pin) problem. So I cut it off and have solder based replacement. BUT... the wiring seems "mysterious" to me. I can't see how this can work or even ever worked. Attached is a picture of the wires (less the phono plug). One sheath has what I believe is two enameled wires while the other has basically...
              09-01-2023, 07:27 AM
            • repair-it
              SONY ZX66i No Sound ... confused
              by repair-it
              Need help from Audio Expert troubleshooting a no sound fault (everything else works) SonyZX66i https://www.manualslib.com/manual/15...page=57#manual
              I replaced the STK 412-150 chip. I have no voltage on ic pin 16 (bias) & no negative voltage on pin 12 which is probably why the bias is 0. I checked the voltages on Q610 and have 71v on both base & emitter but 0v on the collector.
              I'm not sure where the missing negative voltage on the collector should come from. Does it mean that the transistor Q610 is bad?
              03-11-2023, 10:35 PM
