SONY ZX66i No Sound ... confused
  • repair-it
    • Nov 2020
    • 116
    • US
    Need help from Audio Expert troubleshooting a no sound fault (everything else works) SonyZX66i https://www.manualslib.com/manual/15...page=57#manual
    I replaced the STK 412-150 chip. I have no voltage on ic pin 16 (bias) & no negative voltage on pin 12 which is probably why the bias is 0. I checked the voltages on Q610 and have 71v on both base & emitter but 0v on the collector.
    I'm not sure where the missing negative voltage on the collector should come from. Does it mean that the transistor Q610 is bad?
  • R_J
    • Jun 2012
    • 9588
    Re: SONY ZX66i No Sound ... confused
    Is the base voltage on Q610 around .7v lower than the emitter? if not, check the Mute control circuit Q606, Q604
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • Akuanka
      Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
      by Akuanka
      I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
      Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
      Thanks in advance for your help!
      11-23-2024, 01:12 PM
    • KYBOSH
      Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
      by KYBOSH
      Previous owner said TV just went blank one day.
      They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
      Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
      The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
      There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
      I just downloaded the Sony KD-75X7800F Service Manual and...
      11-19-2024, 10:12 AM
    • x_orange90_x
      Sony Bravia KD-50X690E NO SOUND
      by x_orange90_x
      Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
      Has anyone else had this happen to their tv?
      10-05-2024, 05:01 AM
