Cheap meters.
  • archery1
    • May 2018
    • 14
    • usa
    #61
    Re: Cheap meters.
    What would be a good multimeter to get just to work on my tv? No need to break bank I don't use a multimeter much.Just wanted one to test out my samsung plasma tv
      • 31214
      Re: Cheap meters.
      budget?
      • archery1
        • May 2018
        • 14
        • usa
        #63
        Re: Cheap meters.
        Originally posted by stj
        budget?
        something that will be good for working on this tv that i plan on giving to my in laws. I do not use multimeters often so i do not need something expensive.
          • 31214
          Re: Cheap meters.
          well i cant recommend some cheap shit if your using it in a plasma because the voltages get a bit high,
          this is a very good meter if you dont do anything stupid.
          https://www.banggood.com/ANENG-AN800...p-1273474.html
          and this has better safety fuses if your working on mains.
          https://www.banggood.com/UNI-T-UT139...p-1020193.html
          sure, there are dozens of cheaper meters, but if you want to trust what you see and have good functions.
          well those are the ones before it really gets expensive.
          you can probably get them cheaper on aliexpress too - but delivery often takes forever.
          • chth96
            by chth96
            03-09-2024, 10:03 PM
          • eccerr0r
            lowest current galvanometer/analog meter (passively powered!)
            by eccerr0r
            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
            04-16-2025, 12:41 AM
          • jorpec
            by jorpec
            Hi
            Thnaks
            01-23-2023, 10:37 AM
            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
            12-14-2023, 07:45 PM
            Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
            I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
            https://www.aliexpress.us/item/32568...yAdapt=glo2usa
            What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
            03-30-2025, 11:05 AM
