Unsoldering old Mosfets and Soldering in new
  • solderman
    • Jan 2006
    • 9
    I have some mosfets that I would like to replace with new ones. (They are N310AS) I bought a few new ones from Mouser. (The part number on them are NF30AB made by Fairchild)
    I would like to replace 4 of them. Not sure if they are going bad or not. One of them gets pretty hot.(at least I know it did before I recapped it, you can see some of the green coating missing from the board around it) The board still works after I recapped it.
    I had to recap it, as it was dead.
    My questions are, What is the best way to unsolder and remove the old ones? And the correct way to solder in the new ones? What end gets soldered first, the heat sink side or the side with the 2 legs? And what type of iron would be the best to use with what type of solder?
  • Rainbow
    • Aug 2005
    • 1375
    Re: Unsoldering old Mosfets and Soldering in new
    How hot is hot? What board is that? A photo would be nice.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      VRM's are supposed to get hot... Most can handle 100°C... However many mainboard manufacturers are then very smart and place caps right next to them... Err, or not so smart...
      Though if one of them is becoming allot warmer than the others you might have a problem, question is, how much warmer?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i heat each leg and lift with a dental hook.
        once both are free i use a 60w iron with a screwdriver tip to heat the top of the tab.add a bit of solder if needed.
        when it melts i pick it up with hemostats.
        • Rainbow
          • Aug 2005
          • 1375
          That works fine for big packages (TO-263). I use 75W soldering gun.
          For small packages (TO-252), never lift the legs! The legs are very fragile and can easily crack/break.
          • AK0R
            • Mar 2005
            • 204
            If the MOSFET is being replaced, why would that matter? If replacement is being performed due to failure or degradation, the parts aren't going to be re-used on another board, so salvagable condition isn't really important.
            • Rainbow
              • Aug 2005
              • 1375
              Oh, I forgot to write that this applies when desoldering good parts from bad board. I only use mosfets from non-repairable boards as replacement as it's almost impossible to buy them new here.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                i heat a scrap board from underneath and pick the parts off as the solder melts.i use a cheap heatgun.
                harbor freight has one for 9.99
                i salvage vrm ic's fets tantalums,ect.
                • davmax
                  • Dec 2005
                  • 899
                  You must have a good success rate. Surely there are increased risks in recycling. This is an interesting isssue.
                  160Gb WD SATAII Server grade
                  Nvidia 8500GT 256Mb
                  Samsung 18x DVD writer
                  33 way card reader
                  Windows XP Pro SP3
                  17" Benq FP737s LCD monitor
                  • Rainbow
                    • Aug 2005
                    • 1375
                    Reusing the components from totally bad boards is the cheapest way to fix other boards. And it can be also the best way if you get exact replacement if it's otherwise unavailable.
                    For me, the success rate is very high. You need to be careful when desoldering and then test the component that it's not totally bad (diode test on a multimeter is good way to test various components including mosfets).
                    • Smithrll46
                      • Feb 2006
                      What is the recommended technique for soldering the MOSFET back onto the motherboard? How you solder the flat side to the backplane?
                      • Rainbow
                        • Aug 2005
                        • 1375
                        I use old (older than me ) 75W soldering gun. I heat up the board a bit, then add solder. While still heating, put MOSFET there using tweezers. The MOSFET is cold, so the solder will harden without a proper joint - so it still needs heat. When the MOSFET gets hot enough, the solder under it will melt again - then adjust its position using tweezers and remove the soldering gun, careful not to move the MOSFET out of its place. Leave it cool down and then solder the other two pins.
                        • davmax
                          • Dec 2005
                          • 899
                          Replacing MOSFETs is not too simple. First thermal shock should be avoided see this link:
                          http://www.st.com/stonline/products/literature/an/5037.pdf
                          Low temperature solder should be used. See details of this link:
                          http://www.howardelectronics.com/chipquik/smdrepar.html
                          It would seem that a solder loaded paste is a good way to go.
                          Nvidia 8500GT 256Mb
                          33 way card reader
                          Windows XP Pro SP3
                          • arneson
                            • Sep 2005
                            • 1267
                            I also have an old soldering iron. It looks like a cattle prod and gets very hot.
                            The tip is huge so it's only good for the big ugly joints, like a PSU main.
                            If I'm fast I can remove and resolder the FET's with it.
                            Jim
                            • davmax
                              • Dec 2005
                              • 899
                              Yes you need to be fast. Preheating and high power soldering iron say 80W is required. But recommend solder paste when installing new MOSFET. 135F solder is not recommended for these devices, it would let go under normal conditions. Flaming obvious for some.
                              Nvidia 8500GT 256Mb
                              33 way card reader
                              Windows XP Pro SP3
                              • BlackScreen_22
                                Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                by BlackScreen_22
                                Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                I had no problems connecting mosfets and capacitors,...
                                08-27-2024, 12:46 PM
                              • kotel studios
                                Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                by kotel studios
                                Finally got time to fix this board up.
                                At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                04-22-2025, 05:08 AM
                                by momaka
                                03-15-2023, 10:17 PM
                              • flerre
                                Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                by flerre
                                Hi!
                                Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                So, could I safely assume all of these 3 mosfets are...
                                03-13-2022, 12:14 PM
                              • DrDos
                                kenwood kr-6030 Mosfets?????
                                by DrDos
                                Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                                09-20-2025, 04:42 PM
