esr meters bob parker esr micro 4.0 ?
  • gerg
    • Nov 2010
    • 278
    Yes i did a search but there is almost too much information out there on which ESR meter would work best for me. Electronics repair has become less of a hobby but more of a job to me. At work I repair a couple of motherboards per week and a couple of acer monitors thrown into the mix also. ESR meter would be a great tool to have around here. I got the OK from the boss to get one ordered but I am unsure which one is going to be good for me my price range is around 100$ and I would like it prebuilt so i can use it straight out of the box.
    Any suggestions would be great and thanks in advance
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: esr meters bob parker esr micro 4.0 ?
    I got 2 esr micro v4.0 meters, one for me and one for a friend that is tech at the university.
    It's a great tool, we have really nothing to complain about it, and the price was very reasonable
    • smason
      • 1652
      I accidentally tested a charged cap with my ESR Micro the other day.
      Zap!! followed by some profanity, then sinking feeling in my stomach.
      Not sure if there's protection built-in but it still works perfectly. Whew! Love this little unit.
      • Bob Parker
        Technician
        • Feb 2007
        • 182
        Naturally I can't give an unbiased opinion on this subject...
        It is a good shrubbery. I like the laurels particularly...
        • TheLaw
          • Jan 2011
          • 477
          Bob, is it possible that you can sell just PCB? I'd be interested.
          • Bob Parker
            Technician
            • Feb 2007
            • 182
            I only designed the ESR meter and I've never supplied kits or PCBs etc for them.
            If you wanted to get a PCB on its own, you could try asking Anatek Corp if they'll supply you with one. But I have to say that it's much easier to simply get hold of the complete kit and then you don't need to source any special parts like the programmed microcontroller chip.
            Or you could get one of the Russian meters and be checking caps 5 minutes after you open the box.
            • Taurus12
              Optiplex 3050 micro 2 blinks followed by 3 blinks issue
              by Taurus12
              Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
              I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
              i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
              Any recommendation on what I have to do next? Thanks in advance
              06-10-2025, 05:05 PM
            • Isabella91
              Possible to convert eMMC Socket to a micro SD Card socket?
              by Isabella91
              I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
              Read/Write a Micro SD Card from an eMMC Socket.
              I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
              Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
              Not to remove...
              01-14-2024, 05:10 PM
            • Stunt
              Dell Optiplex Micro 7010 Computrace
              by Stunt
              Device: Laptop
              Brand: Dell
              Model: Dell Optiplex Micro 7010
              Board : 212045-1
              S/T : 2RP6VX3
              Request : Computrace Unlock
              08-12-2025, 06:15 AM
            • Altemon Moura
              Optiplex 3000 micro
              by Altemon Moura
              Unfortunately, when removing the chip
              (GIGADEVICE 25R256EYIG)
              It broke in the hot air.
              Will I be able to buy this same model?
              (GD25R256EYIG)
              "Can I burn the Bios?"
              motherboard
              DELL Optplex 3000 - 202040-1 D10NK$HA
              Optiplex 3000 micro
              Service tag: C7CG7T3
              SERVICE CODE: 26565563271​
              05-20-2025, 06:35 AM
            • tracks
              Dell 3080 Micro BIOS dead
              by tracks
              Hello all,
              I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
              Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
              I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
              04-19-2025, 03:42 PM
