Chinese hot air and soldering stations
  • NanoTesting
    • Sep 2023
    • 8
    • Mexico
    What is the consensus? are they useful or trash even in a short term scenario?
    Going to buy a hot air station and Yihua and Baku ones look popular in the "budget" range.
    I will eventually upgrade to an Atten or Quick.
    For example: and
    Are some of the models im going to buy, the Yihua one has some reviews that make it sound decent in EEVBlog and other sites also repair guides so i guess i will opt for that.
    But they all use the same heat gun that looks like it will melt eventually, and that has often reviews of having "dust" inside them on the first use doesn't matter which model they are on that people warn you to never inhale.
    Got a stubborn customer that wants ME and only me to replace a SuperIO that exploded in a Y540 because he used a charger with a broken tip for a year till it finally sent 20v through the ID pin and he is willing to pay me to get one to do it so a cheap one it is i guess.
  • petehall347
    • Jan 2015
    • 4427
    Re: Chinese hot air and soldering stations
    use a soldering iron charge top dollar and put towards decent hot air station .
    unless its soldered on the back that is .
    • R_J
      • Jun 2012
      • 9550
      From other pictures, the ic does not seem to have a solder pad under it. You could use a sharp (x-acto) knife and carefully cut all the pins, making sure not to cut any traces, then using a soldering iron, remove each pin from the board, then resolder the new ic using plenty of flux.
      • NanoTesting
        • Sep 2023
        • 8
        • Mexico
        The SuperIO doesn't have a bottom pad but other things i need to change (RT6585B for example) do.
        And well shitty tool beats no tool.
        • clearchris
          • Dec 2013
          • 687
          If you are going cheap, get the cheaper hot air, spend more on an iron. I don't see a lot of savings from getting the all-in-one units, I'd prefer separate machines.
          If you are just starting out, the pinecil is pretty good if you can find an old 20v laptop charger that you can cut apart. For hot air stations, a lot of people use the cheap ones, but I think skill matters a lot more than the hot air tool (at least in my unskilled hands).
          • reformatt
            • Feb 2020
            • 1414
            I have tried cheaper ones, but the one I have is collecting dust somewhere. Spend the extra and get something like a Quick.
            One of the major benefits of the Quick machines is the ease to swap nozzles (I have a TR1300, same nozzles as the 861DW). The cheaper ones use a screw on clamp, which is a PITA if you have to swap often. Quick also have angled nozzles too, which is great for when you are doing stuff under a microscope. Quick have a variety of sizes from 3mm, up to 12mm. The nozzle you use is actually quite important and will dictate how much stress you put the board and component under during removal.
            I also get consistent heat out of my Quick, something I don't think you get on the cheaper ones. The cheaper ones are all over the place with heat delivery and not consistent.
            But if you are wanting it for things like EC removal, then cheap ones will do. It's a far easier proposition applying ChipQuik on those 128 pin packages. You need very little heat to remove them as a result and you won't rip any pads. If you use ChipQuik, make sure you get it all off the board, as it's not electrically conductive.
              • 31048
              this guy reviews soldering gear
              https://www.youtube.com/user/sdgelectronics/videos
              • redbaron1007
                • Jun 2021
                • 107
                What's your budget? If you're looking for cheaper now and better later you're still better off spending a little more on separate soldering and hot air stations. There's pretty good cheap jbc and hakko clones out there that'll get you by for around $100. A friend of mine has a Aixun station and loves it compared to the cheapo combo station he had before and it was maybe $100 after shipping.
                Hot air is where spending more money is worth it in the long run, but if you're looking for something affordable this one from Quick is supposed to be pretty good if you get a genuine one and is pretty unlikely to catch on fire in your hand.
                https://www.tequipment.net/Quick/957.../?b=y&v=171729
                Stations that have the blower in the base unit and not he handpiece tend to last longer and are much more comfortable to use and control where you're directing the air.
                Edit: Forgot to mention I don't recommend buying anything like this off amazon because of the rampant counterfeits. I've gotten counterfeits of counterfeit tools before and let me say those were some of the most awful under-performing tools I've ever seen for the money.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  If you don't want to spend a lot then for the most common uses an 800W or 1000W station is sufficient. I have been using a 952D for years. It is very important to continuously move the air flow as its temperature is much higher than desired and you risk burning the chip. For example, ite chips can also be desoldered with a standard nozzle but you need to move the air flow in a circular manner and never to the center of the chip, add flux if necessary.
                  • Peter_1402
                    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                    by Peter_1402
                    Hi Everyone,
                    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                    1. Soldering iron works great
                    2. There is a burnt mark on the hot air gun handle.
                    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                    Reed switch tested ok with a magnet.
                    From the above test, I can conclude...
                    07-12-2025, 11:50 AM
                  • aaronmacdonald
                    Mix & Match Hot Tweezers with Station
                    by aaronmacdonald
                    Hey guys; I have a cheap soldering station (Txinlei 8586) and was wondering if it was possible to use Aoyue hot tweezers on it.
                    Digikey has a couple options for Aoyue hot tweezers available, and although you're not really "supposed to" use them on anything other than intended Aoyue stations, I was wondering if any of you have experience/knowledge and can tell me if I can safely use any of the available options on my cheap station.
                    These are affordable, and the quick shipping speed (I'm about to do a digikey order anyway) makes them attractive over a Chinese...
                    08-29-2022, 08:00 PM
                  • Azurain
                    Elitebook 840 G5 Bios Chip Soldering Question
                    by Azurain
                    I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                    Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                    04-14-2023, 06:58 PM
                  • clearchris
                    New Cheap Chinese Soldering Plates
                    by clearchris
                    I was browsing on ali, and I'm seeing a bunch of these super cheap soldering hot plates. I was going to make one, but it's really hard to justify DIY when you can buy a plate for under $10.
                    Most look pretty functional, one looks like it needs to have the plate flipped, and they could all stand to be countersunk and swap the screws for flat head ones. Would be nearly trivial to install an arduino, thermocouple and ssd for fine control.
                    https://www.aliexpress.com/item/1005003127491986.html
                    https://www.aliexpress.com/item/1005001445767919.html
                    https:/...
                    10-29-2021, 11:27 AM
                  • valente222
                    help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                    by valente222
                    Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                    05-12-2025, 03:42 PM
