Remove excess solder
  • viewerau
    • May 2020
    • 305
    Can someone tell me how (or if) I can remove this excess solder?
    I made a novice boo boo.
    The board is an edge board from an lcd tv, and it connects to the tv panel via a fixed cof strip.
    I had to remove a surface mounted multi diode chip (yes I did a bad job) but got some residue solder on the pins when cleaning it up with a ribbon wick.
    Can I get that excess off, as I believe it is causing interference to the panel, shorting or something, that effects just a small portion of my image.
    Any pointers please?
    Thank you
    Signature:Seemingly hopeless tv fixer
  • lotas
    • Jan 2016
    • 4601
    • Russia
    Re: Remove excess solder
    To do this, there is a braid to remove solder.
    https://aliexpress.com/item/1005004037729600.html
    https://aliexpress.com/item/32958719300.html
    • CapLeaker
      Leaking Member
      • 8158
      Solder residue like burnt flux flux? Use 99% IPA and a toothbrush.
      • viewerau
        • May 2020
        • 305
        Thanks CapLeaker and lotas
        It is that type of solder wick that I used when taking off the chip...do I now simply use more with a warm iron?
        My worry is that when doing so, that it might try to remove the actual end tips that I require to still stay there?
        • CapLeaker
          Leaking Member
          • 8158
          The pic isn’t very clear. To me it looks like burnt (black) flux that needs to be cleaned.
          • viewerau
            • May 2020
            • 305
            Does this help?
            • CapLeaker
              Leaking Member
              • 8158
              Put a lot of flux on there and clean that up with your soldering iron using a chisel tip or similar. If that is indeed solder it should stick to your iron, just clean the iron after every stroke. Then clean the spot with 99% IPA. When the flux gets brown and thick, wash it away and put more new flux. Be gentle on the tab bond. If you can select the temperature of the tip don’t run it full bore. 280C or 300C should be more than enough.
              • viewerau
                • May 2020
                • 305
                Thank you for your reply.
                As you can see, I am only new at this, so please forgive the extra questions?
                When I removed the chip, all I did was heat up the iron, to remove the chip.
                I did not use anything else, and as the solder was melting, I used some tweezers to pull it off the board.
                I then got hold of my solder wick tape, putting that on the area, and then tried to soak up the remaining solder left over.
                I think(??) at that time, I must have slopped some of the solder off the wick, and onto those pin areas when doing so.
                It is now my duty to try remove that slop.
                I have not used flux before, so I need to buy some to try to clean it up.
                Do I have it right, following your reply, that I simply have to put the goo I am buying....https://www.ebay.com.au/itm/29492421...Bk9SR-DxiOvAYg
                onto the area, warm iron, and try to get solder off one wipe at a time, until it is gone?
                I only ask, because when I try to look at youtube videos, they seem to say to buy isopropyl 99% and try to clean it with that, by wiping or using a toothbrush.
                This is where I get confused, and don't wish to make my job worse, rather than better.
                Can you please advise again?
                My apology for being rather dim.
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  first clean it with isopropyl 99% . then see how it looks .
                  • harp
                    • Jun 2022
                    • 599
                    • Planet Earth
                    I think that connector isnt firmly affected with solder yet, so use toothbrush and any alcohol, and if you have hard sticked particles use a wooden toothpick to scrap it...
                    But, you must also clean your initial "working area" around chip, to see what is going there... I see some ripped pads, maybe bridges... you cant work without proper tool, I think some flux and be familiar with technique. Practice on scrap board before try to fix something.
                    • viewerau
                      • May 2020
                      • 305
                      It all cleaned up perfectly after using iso again, the set now runs perfect after following this thread...https://www.badcaps.net/forum/showthread.php?t=116525
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                        Multifix 425-01 and 450-01 Rework Flux Datasheet
                        REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                        - No Clean Formulations
                        - Low residue
                        - Range of activity to deal with different component solderability
                        - Halide free
                        - Suitable for dispensing
                        - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                        Both products are supplied in syringes or cartridges for application by dispensing....
                        10-07-2024, 06:02 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • ktmmotocross
                        recommend good solder wick on aliexpress
                        by ktmmotocross
                        I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
                        02-08-2024, 12:48 AM
                      • Geeker007
                        Friend messed up my laptop motherboard while working on my bench
                        by Geeker007
                        Hi All,
                        So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                        So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                        I have not tried putting...
                        06-16-2025, 01:40 PM
