Tenma 72-040 Cap Meter
  • Solder Boy
    • Nov 2006
    • 178
    Hi guys! I won this cap meter off Ebay earlier this month.. finally got it today..everything works on it.
    Just have a question about reading the higher capacitance levels.. this thing goes as high as 20 000 uf and the meter has a selector switch on it that says 20mf.
    It has a digital LCD on it.. if I test a used 3300 cap for example.. it reads 3.26 or close to it. Does this mean 3.26x1000 for a reading of 3260uf or does it mean 3.26 and the cap is shot?
    I tested some 6.3 1000uf caps and that was easy... it read 850uf.
    My next question is how much of a leeway eitherway is acceptable before you determine the cap to be bad? Is 850uf on a 1000uf cap ok? I kinda figure 700uf and below is bad.
    Thanks guys!
    www.bcrelectronics.ca
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Tenma 72-040 Cap Meter
    Almost all caps are rated for a tolerance of +/- 20% (make sure with the data sheet, if you can find one, if you are unsure)
    850/1000=.85
    1-.85 is .15
    .15x100=15
    So 850uf out of a labeled 1000 would be 15% below the labeled rating, which is in spec.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      If there is an (M) on a cap then it is +/-20%.
      Don't confuse with the Panasonic/Matsushita [M] though.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Yes, 3260uf
        - Dr Seuss
        • Quasar
          • Sep 2010
          • 132
          mF = millifarad
          uF = microfarad
          1mF = 1,000uF
          3.26mF = 3,260uF
          Meter came with no book? It's usually explained or charted in the manual.
          • microtech
            • Jan 2012
            I have the manual--it's only a couple pages--ur welcome to it if u want.
            • chth96
              by chth96
              03-09-2024, 10:03 PM
              12-31-2023, 06:04 AM
            • jorpec
              by jorpec
              Hi
              Thnaks
              01-23-2023, 10:37 AM
              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
              12-14-2023, 07:45 PM
            • Stephan Mathers
              EDMI ATLAS MK10 Electronic Meter Discussion
              by Stephan Mathers
              Greetings, new guy here but always interested in the crazy universe of modding
              We just finished construction of around 25 vacation houses, all inside the same private area.
              Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
              The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
              Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
              05-20-2025, 09:09 AM
