ASUS X705UVP Bios
  • Conste
    • Oct 2018
    • 235
    ASUS X705UVP Bios
    My ASUS F705UA (this is standing on the baseplate) just bricked itself with an UEFI update.
    Tried a bios dump from the www but problem is the same, no screen and battery light blinking white.
    Could somebody please repair my original one?
    Mainboard: X705UVP Rev. 2.1
    Thanks in advance.
    • 21936
    Re: ASUS X705UVP Bios
    Post a picture of the white barcode sticker on the motherboard
    • Conste
      • Oct 2018
      • 235
      Downloaded 2 files from fixbios for money, but no sucess.
      Picture is attached
        • 21936
        Picture is attached
        Those aren`t the stickers i would hope you would post. The stickers are like the ones in this thread - https://www.badcaps.net/forum/showthread.php?t=96604 .Sometimes there`s QR codes instead ,or no stickers at all.
        So the laptop model is F705UA ,the motherboard silkscreened part number is X705UVP Rev. 2.1 ,and we don`t know if there should be another sticker or not (with a model number and bios version), so its hard to find which bios you need .
        Your bios update was to X705UVP and that doesn`t seem to be working.The F705UA support page has X705UAR - https://www.asus.com/FR/supportonly/...HelpDesk_BIOS/ ,we`ll try that one
        did you check if the bios from the "paid" site had clean ME firmware
        • Conste
          • Oct 2018
          • 235
          I think the correct model is
          X705UAP, because I can also find this string in my bios file using ctrl + f
          https://www.asus.com/supportonly/X705UA/HelpDesk_BIOS/
          /Edit: No sucess. Could you build a dump of X705UAP, please?
            • 21936
            X705UAP me clean. My bad,i should have looked at the strings too.
            • Conste
              • Oct 2018
              • 235
              Thanks!
              But sadly, no change.
              I can see that one rail in CPU area is not coming on, but since there is no schematic I guess the chance to repair it is very low.
              Could it be that the KBC has a bad flash?
                • 21936
                X705UVP Bios
                • Conste
                  • Oct 2018
                  • 235
                  Thanks, but still the same
                  • razor_amd
                    [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                    by razor_amd
                    With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                    For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                    I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                    This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • grimacelord
                    ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                    by grimacelord
                    I have spent the last hour on this and I guess this is just over my head, so here I am.
                    I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                    The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                    Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                    07-10-2025, 02:52 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • throwaway327
                    Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                    by throwaway327
                    ASUS ROG Ally X - (Handheld Gaming PC)
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                    I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                    06-18-2025, 05:52 PM
