Lenovo flex-15iml MODEL NAME:81XH NEED BIOS DUMP
  • badbane
    • Aug 2021
    • 10
    The user power cycled during a lenovo firmware flash and I am trying to get it back up and running from the dead.
    • 21451
    Re: Lenovo flex-15iml MODEL NAME:81XH NEED BIOS DUMP
    Post the corrupt backup here and someone will help.
    • badbane
      • Aug 2021
      • 10
      attached the rar bin file from the nonresponsive laptop.
      • badbane
        • Aug 2021
        • 10
        See attached for bad bin file backup from the lenovo flex
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria šŸ‡§šŸ‡¬
          45.0 KB?
          Try again.
          Become a Badcaps supporter
          Thanks to all supporters.​
            • 21451
            Originally posted by Vesko356
            45.0 KB?
            Try again.
            Maybe the OP is using a CH341A with a clip
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria šŸ‡§šŸ‡¬
              For sure,I can bet. These two are just great combination, an absolute guarantee for a job well done
                • 21451
                Try and make another backup,its more reliable to desolder the chip if you have the tools.If you havn`t and you are using a clip make sure it doesn`t wobble about and it makes good contact. Make 2 backups and compare them with a hex editors "File Compare" function, and lookat the files to make sure there`s some code there other than all FF`s.
                • badbane
                  • Aug 2021
                  • 10
                  Yo got me yes I am using a ch341a with a clip. I am able to get it to read but the chip is not listed with the application I'll try pulling it again.
                  • badbane
                    • Aug 2021
                    • 10
                    FYI I had to rar the bin file which is 64 kb. since the site would not let me upload a .bin file directly. I can see that there is hex data. My fear is that the ch program is not detecting the proper chip and is pulling less data than it should.
                    • badbane
                      • Aug 2021
                      • 10
                      I am still working my around this ch341a I would love to know if you all have a software you recommend to work with other than the ch341 program. I as asprogrammer too.
                        • 21451
                        Try NeoProgrammer from this post,and check if you have 5V on pin 28 ,you can mod it to make it a bit more stable
                        https://www.badcaps.net/forum/showpo...50&postcount=5
                        • badbane
                          • Aug 2021
                          • 10
                          I think I go it working with the AS programmer software.
                            • 21451
                            Here`s your bios + DMI .
                            • badbane
                              • Aug 2021
                              • 10
                              The bios is confirmed working. Thanks.
                              • hari_tec
                                • Aug 2021
                                • 8
                                • India
                                thank you its working:
                                • gatonieve
                                  • Dec 2023
                                  • 1
                                  • PERU
                                  good afternoon, could you help me with this bios, there is no image when I turn on
                                  • Vesko356
                                    Vesko356 commented
                                    Editing a comment
                                    https://www.badcaps.net/forum/troubl...before-posting
                                    You MUST:
                                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                    • ​Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms.
                                      Name your thread with make, full model numbers and request.
                                • AHmad_Salal
                                  Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                  by AHmad_Salal
                                  Hello all,
                                  I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                  11-28-2023, 05:28 AM
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • hyperwood
                                  [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                  by hyperwood
                                  Hi everyone,
                                  I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                  The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                  I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                  āœ… What I need:
                                  • A working 2MB BIOS dump
                                  • Matching NM-E471 Rev. 2.0, e.g. JY575
                                  06-25-2025, 02:28 PM
                                • Captaincrap420
                                  Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                                  by Captaincrap420
                                  Hi, I hope this is the right place to post this. This is my first post on this forum.
                                  A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                                  This bios dump is straight from the chip, nothing has been...
                                  11-29-2024, 05:40 PM
                                • jendkkd jeje
                                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                  by jendkkd jeje
                                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                  10-11-2024, 03:12 PM
