Lenovo flex-15iml MODEL NAME:81XH NEED BIOS DUMP
  • badbane
    • Aug 2021
    • 10
    The user power cycled during a lenovo firmware flash and I am trying to get it back up and running from the dead.
    • 22084
    Re: Lenovo flex-15iml MODEL NAME:81XH NEED BIOS DUMP
    Post the corrupt backup here and someone will help.
    • badbane
      • Aug 2021
      • 10
      attached the rar bin file from the nonresponsive laptop.
      • badbane
        • Aug 2021
        • 10
        See attached for bad bin file backup from the lenovo flex
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria šŸ‡§šŸ‡¬
          45.0 KB?
          Try again.
          Become a Badcaps supporter
          Thanks to all supporters.​
            • 22084
            Originally posted by Vesko356
            45.0 KB?
            Try again.
            Maybe the OP is using a CH341A with a clip
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria šŸ‡§šŸ‡¬
              For sure,I can bet. These two are just great combination, an absolute guarantee for a job well done
                • 22084
                Try and make another backup,its more reliable to desolder the chip if you have the tools.If you havn`t and you are using a clip make sure it doesn`t wobble about and it makes good contact. Make 2 backups and compare them with a hex editors "File Compare" function, and lookat the files to make sure there`s some code there other than all FF`s.
                • badbane
                  • Aug 2021
                  • 10
                  Yo got me yes I am using a ch341a with a clip. I am able to get it to read but the chip is not listed with the application I'll try pulling it again.
                  • badbane
                    • Aug 2021
                    • 10
                    FYI I had to rar the bin file which is 64 kb. since the site would not let me upload a .bin file directly. I can see that there is hex data. My fear is that the ch program is not detecting the proper chip and is pulling less data than it should.
                    • badbane
                      • Aug 2021
                      • 10
                      I am still working my around this ch341a I would love to know if you all have a software you recommend to work with other than the ch341 program. I as asprogrammer too.
                        • 22084
                        Try NeoProgrammer from this post,and check if you have 5V on pin 28 ,you can mod it to make it a bit more stable
                        https://www.badcaps.net/forum/showpo...50&postcount=5
                        • badbane
                          • Aug 2021
                          • 10
                          I think I go it working with the AS programmer software.
                            • 22084
                            Here`s your bios + DMI .
                            • badbane
                              • Aug 2021
                              • 10
                              The bios is confirmed working. Thanks.
                              • hari_tec
                                • Aug 2021
                                • 8
                                • India
                                thank you its working:
                                • gatonieve
                                  • Dec 2023
                                  • PERU
                                  good afternoon, could you help me with this bios, there is no image when I turn on
                                    Vesko356 commented
                                    Editing a comment
                                    You MUST:
                                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                    • ​Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms.
                                      Name your thread with make, full model numbers and request.
                                • AHmad_Salal
                                  Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                  by AHmad_Salal
                                  Hello all,
                                  I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                  11-28-2023, 05:28 AM
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • hyperwood
                                  [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                  by hyperwood
                                  I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                  The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                  I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                  āœ… What I need:
                                  • A working 2MB BIOS dump
                                  • Matching NM-E471 Rev. 2.0, e.g. JY575
                                  06-25-2025, 02:28 PM
                                • mkdj
                                  by mkdj
                                  Dear all,
                                  10-19-2025, 04:41 AM
                                • mkdj
                                  Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                  by mkdj
                                  Dear all,
                                  I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                  Here the steps I have taken to fix the laptop:
                                  - downloaded latest BIOS from Lenovo Website...
                                  10-18-2025, 03:43 AM
