GA-7VA need help poly modding
  • c_hegge
    • Sep 2009
    • 5219
    I have a Gigabyte GA-7VA to refurbish. It has a vented Rubycon MBZ (the one with the white arrow pointing to it) next to a coil. I suspect that the coil has been hot and overheated it. I'm thinking about poly modding this board. I've mentioned what the current caps are in the pic. I'm considering the following caps:
    Red - 680uF poly (http://cgi.ebay.com.au/4-NCC-PSA-6-3...item439b794284)
    Yellow - 820uF Poly (http://cgi.ebay.com.au/4-Sanyo-SEP-6...item439c82586e
    Green - 1500uF Poly (http://cgi.ebay.com.au/2-Sanyo-SEPC-...item45effd88cc)
    Blue - 1000uF Poly (http://cgi.ebay.com.au/4-Fujitsu-RE-...item45ed32bfdb)
    Can someone tell me whether or not these are appropriate replacements?
  • c_hegge
    • Sep 2009
    • 5219
    Re: GA-7VA need help poly modding
    Hello? Anyone?
    • c_hegge
      • Sep 2009
      • 5219
      I've ordered the caps. I ended up going with 820uF for the blue ones and 560uF for the yellow ones. Will post back with results.
      Sorry for not using getting them from here, but topcat doesn't have all those sizes
      • c_hegge
        • Sep 2009
        • 5219
        I've done the poly-mod and so far so good, although I haven't given it much stress testing yet.
        • c_hegge
          • Sep 2009
          • 5219
          Here's a pic
          • shadow
            • Feb 2007
            • 732
            It looks like a good job.
            I have a spare GA-7VA revision 1.0 board to offload...I was going to recap mine but never got around to it. And now I have no use for the system.
            The original Choyo caps are known to bulge. There is a picture on these forums somewhere where they have bulged so far that the caps were at 45 degree angles compared to the motherboard!
            • c_hegge
              • Sep 2009
              • 5219
              It's been running overnight in a Prime95 Blend test and no problems yet. It was quite a pain to get some of the caps in there since the legs are slightly thicker. Also, the 820uF 6.3v Polys are 10mm diameter while the original lytics were 8mm, so it was a tight squeeze in some places, but it works. I think it should now be called a GA-7VA-DS3L
              • Scenic
                o.O
                • Sep 2007
                • 2642
                the L usually stands for Light/Lite (stripped down cheapo board, fewer options in BIOS) .. doesn't quite match
                (if you don't count the missing onboard LAN)
                edit: wtf happened to the NB fan screws?
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  it's ok, I forgive ya. I'm working on some poly sourcing, so in time, I will have these in stock.
                  Looks like a great repair, well done!!
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • c_hegge
                    • Sep 2009
                    • 5219
                    I call it a DS3L and not DS3 since there is no onboard lan. The board didn't originally have a northbridge fan, but it got hot so I added one.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Still going strong after ~44hrs in Prime95 (24Hrs Blent test, 20Hrs In-Place FFT). I'll run memtest overnight and see how it goes there. If still no problems, it should be safe to say it's fixed.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        It's looks like it's going to be OK. I'm posting from it now.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          We found another GA-7VA at work. This one had no bad caps, but the middle DIMM slot was faulty (wouldn't detect any RAM in it). I re-soldered the pins and now the slot works. I also gave it a full poly-mod and, rather than putting a fan on the northbridge heatsink, I replaced it with a bigger passive cooler.
                          • chth96
                            How can I test coil whether it is really broken or not?
                            by chth96
                            I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                            I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                            I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                            I want to replace this round black fuse and unidentified coil if it got broken.
                            02-20-2024, 01:07 AM
                          • CapLeaker
                            Poly VVX-250 VOIP POE problem not booting fix
                            by CapLeaker
                            I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                            Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                            11-25-2023, 10:46 AM
                          • waterchill
                            What part is this coil from a MacBook A2681 ?
                            by waterchill
                            Hi everyone
                            I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
                            So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
                            IAny ideas? It is from a MacBook A2681
                            Thank you...
                            08-08-2024, 01:46 AM
                          • Gjackson
                            ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                            by Gjackson
                            Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                            01-13-2024, 10:34 AM
                          • chth96
                            How Can I identify IFT coil?
                            by chth96
                            I have a CD unit which is came from saturn game console.
                            It always perceived Any retail CD or CD-R as Audio-CD.
                            Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
                            I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
                            I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
                            Is there any way to identify its frequency in order...
                            11-11-2022, 05:31 AM
