Dell E173Fpf and burnt resis.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4544
    • Italy - Milan
    Hi!
    I've damaged my Sunday morning and over to read other threads
    I have bought this monitor broken, i found soon Q850 'AP-2761I' power mosfet shorted all sides, R856 is burnt and value is unreadable, the explosion may have destroyed also the near pin of a little smd capacitor (ceramic?)
    wich is connected to ground, the other one leg goes to Vdd of the pwm, i don't know its value , reading threads (by mypc2007) one user Bobdee reveal the value of resistor is 15R0 so like a 15 ohm, watching with a lens
    i see that much probably the first/last cipher is 5, then a R or 0, a 1 and finally
    an half 0 (may be a R but isn't the right pos. for it), reading upside down
    can be 0105 but it has no sense, so is it 5R10, then a 5,1 ohm?? Reading Somtam i found too other broken items so finally i have R856, R861, R859 open, Q850 short, like him, plus C856 open (exploded with R856) and
    R852 (visually a bit burnt/damaged and seems open, near big cap past the bridge) .
    I've also read here about one that had replaced Mosfet and big R869 (or R852 don't remeber) and fixed so. The second problem, R852 has strange colour code, is red-black-silver-gold-white, it has no sense, silver as 3d
    ring.. white as last?? Now i go to ebay to watch for mosfet..
    for picture in other threads:
    https://www.badcaps.net/forum/attach...&stc=1&thumb=1
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4544
    • Italy - Milan
    Re: Dell E173Fpf and burnt resis.
    I add in the entry of AC there is a wire instead of the glass fuse, watching the soldering is sure by factory, it's normal? I must replace it?
    • Bobdee
      • Jun 2008
      • 461
      Davi.p
      R852 = red black silver gold gives you 0.2 ohms with tollerance of 5%
      You forget the white as that has something to do with the military failure rating as I recall when I had a problem with same resistor
      • Bobdee
        • Jun 2008
        • 461
        Davi.p
        I have the E173 and E153 boards with me now
        R856 = 15R0 on both boards
        Have taken reading on E173 resistor and find it open
        So I have taken reading on the E153 and it gives me 15 ohms confirming that it is 15R0
        Anything else I can confirm for you, just ask
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4544
          • Italy - Milan
          thankyou , i trust you, unfortunately on ebay only one person sells kit for repair,
          and i have to replace mosfet with something similar (i have to spend times watching
          d.sheets uff!) and also little resistors are hard to find nowadays here .. sob!
          For a 40 euro monitor so hard work.. pant! Ok i let you know if i will fix it..
          If you know a search engine capable of find equivalet transistors..
          bye.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4544
            • Italy - Milan
            i have replaced mosfet with an STP10NK60Z, a N channel 600V 10A (0,7ohm Rds
            Vgs threshold 4,5v Vgs +-30v Ton 20ns) Original is 650v 10A(1 Rds threshold 4v vgs+-30v ton 16ns) unfortunately shop hadn't smd things i replaced R856 with a normal
            thruhole 15ohm, but i repeat with the lens on mine exploded the first number is 5,
            something like 5R10 (=5,1ohm), anyway the condenser with a normal one 10nF 100v
            (original unknown but another user said probably ok cause serves as anti disturb
            , noise, so it must be little, it's on the Vcc line that powers the pwm at 20-30v)
            i powered up and.. PPaaamM! A fire shot.. ( i dunno why...
            • picturevalve
              • Nov 2010
              • 13
              If your board looks like this :
              board
              then R852 is a 0.2ohm 1w metal film
              There are 2 ceramic high voltage caps between the centre heatsink and the 100uF 450V elect. the resistor directly above is the 0.2 ohm, if you have the same board.
              I have an E173FPf monitor where the ceramic cap has ruptured and flashed to the heatsink earth taking out the 0.2 ohm and the 2A mains fuse. The small cap nearest the 100uF is a 10nF 1kV, the ruptured one nearest the heatsink is a 100nF 1kV.
              • picturevalve
                • Nov 2010
                • 13
                R856 on my board is marked 5R10 and measures 5.1 ohm. C856 I cannot measure properly as it seems to have a 10uF in parallel. HTH.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4544
                  • Italy - Milan
                  Thank you picturevalve, the board is the same!.. is strange for the 2 big resistors, 11 near the little pwm ic and the other near big cap., the colour scheme i remember was different, i remember one guy told to me one is 0,2
                  the other is 0,33-0,3. Unfortunately i have taken the item used and found a
                  fucking wire instead of glass fuse! And the 'a little stupid' guy that sold it to
                  me don't seems so good to solder works, the wire appear a factory job (maybe, who knows?). Ceramic round-flat caps you say, in mine seems good..
                  i will check.. now i had doubts about the optocoupler, when it come i will change it and hope.. about the R856 another guy told me also is 5.1ohm, now i know it for sure, i don't know if was it the reason the first repair try it
                  exploded the 0,3 (or 0,2..) ohm resis. near pwm ic..
                  BYE.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4544
                    • Italy - Milan
                    Originally posted by Davi.p
                    11 near the
                    correction: "11 near" is "one near"..
                    • Rtech
                      • Jul 2010
                      • 1095
                      You will probably find the PWM chip is blown as well.
                      • electomech-fixer
                        First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                        by electomech-fixer
                        I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                        I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                        09-15-2025, 01:42 AM
                      • dicky96
                        Zotac GTX 260 burnt component - can anyone identify?
                        by dicky96
                        Hi guys
                        This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                        This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                        Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                        I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                        The good phase...
                        12-01-2021, 01:02 PM
                      • swimllamaswim
                        Precision 5550 LA-J191P No Power, Burnt ISL9538
                        by swimllamaswim
                        I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                        Here are the voltages measured at that chip:
                        To note, DCIN at Pin 17 is low,...
                        09-21-2025, 12:26 PM
                      • mferna14
                        Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                        by mferna14
                        Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                        06-25-2025, 11:26 AM
                      • nobbnobb1
                        Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                        by nobbnobb1
                        I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                        - 1x 3.14 A @ 250V main circuit fuse
                        - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                        - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                        11-16-2024, 09:56 PM
