Lenovo E145 DALI2KMB8D0 REV D Bios dump need!
  • Ariu
    • Dec 2020
    • 138
    Hello ,
    i need a bios dump for this motherboard
    DALI2KMB8D0 REV D.
    It is a Lenovo E145 .
    Please help.
  • peste
    • Dec 2016
    • 13740
    • ROMANIA
    Re: Lenovo E145 DALI2KMB8D0 REV D Bios dump need!
    Originally posted by Ariu
    Hello ,
    DALI2KMB8D0 REV D.
    Please help.
    post the backup of the bios
    • Ariu
      • Dec 2020
      • 138
      thanks for your reply....
      • Ariu
        • Dec 2020
        • 138
        Thank you i have attached the bios files below.
        • peste
          • Dec 2016
          • 13740
          • ROMANIA
          bios extracted from the Lenovo site update.
          DMI FF40-1000F
          • Ariu
            • Dec 2020
            • 138
            DMI FF40-1000F
            Thank you.
            Is this bios for Lenovo E145 DALI2KMB8D0 REV D compatible?
            • Zibbo
              • Mar 2017
              • 205
              • Zimbabwe
              DMI FF40-1000F
              Thank you, working
              • mainah njoroge
                • Aug 2017
                • 36
                • kenya
                Originally posted by zibbo
                thank you, working
                are you shure this file worked for you
                isnot coplete
                • dahnking
                  • Apr 2018
                  • 264
                  • kenya
                  DMI FF40-1000F
                  working tested
                  • almussafer
                    • Jun 2019
                    • 86
                    • Iraq
                    you can try this one i upload the original bios with password and the patched bios from autopatcher program and its worked 100%
                    • AHmad_Salal
                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                      by AHmad_Salal
                      Hello all,
                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                      11-28-2023, 05:28 AM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • hyperwood
                      [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                      by hyperwood
                      Hi everyone,
                      I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                      The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                      I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                      āœ… What I need:
                      • A working 2MB BIOS dump
                      • Matching NM-E471 Rev. 2.0, e.g. JY575
                      06-25-2025, 02:28 PM
                    • mkdj
                      ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                      by mkdj
                      Dear all,
                      I have a ASUS ZenBook UX480F with the following symptoms:
                      I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                      I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                      10-19-2025, 04:41 AM
                    • Habble7
                      I need a BIOS dump for the Samsung S49CG934SU monitor
                      by Habble7
                      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                      Suspected Cause:
                      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
