Best bang for the buck system you could build with native Win7 support?
  • SluggerB
    • Aug 2020
    • 747
    • US
    What would be the latest rev of hardware and CPU technology that would natively support Windows 7? I am fine slip streaming in USB3 drivers if the mobo only has those, but I am leary about building a ryzen system that has to rely on unofficial drivers from random message board posts
    My primary usage is generally office type PC stuff,. but I run a few VM's so I would want to go heavy on the RAM (like 32gb which is heavy to me) but also light on the wallet. I already have a spare HDD so that could be left out of the equation.
    Any build suggestions?
    • 31204
    Re: Best bang for the buck system you could build with native Win7 support?
    why dont you run Linux and then virtualize win7?
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      for intel: Skylake
      for amd: no idea
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Originally posted by Uranium-235
        for intel: Skylake
        for amd: no idea
        I never realized Ryzen CPU based systems had no official Win7 support....I've only set up one or two.....for gamers. They ran 10.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          skylake is the last one that has intel HD support. So, some earlier graphics cards can be used on further CPU's, but win7 nixed win7 updates for cpu's passed kaby lake
          for both further, you can technically install win7, but you will eventually loose native USB support. A USB card should work, and some bios's have an options to use ECHI instead of XCHI (USB 3.0)
          Also no motherboard drivers, and lack of extended support. You're going to get a lot of missing drivers in the device manager, and no software to install for them
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            • Romania
            The FX series should have support for Windows 7. Other than that, pretty sure both sides axed Windows 7.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I think you mean am3+ fx. In fact I think all am3+ and lower still have full 7 support. I'm guessing, anyways
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                For best bang4buck, I say grab one of those dual socket 1366 Xeon workstations used. Two high-end 6-core socket 1366 Xeons, for example, can run close to the same speed as a modern last-gen i7. And those workstations often support 3-ch RAM... and lots of it (which tends to be cheap too, due to using registered DIMMS.) Many of those socket 1366 workstations even come with Win 7 Pro COA. So you just slap an HDD or SSD in there and Windows 7 will go on there without any fuss. Now, you may not get the latest CPU instructions and for USB 3, you might need an add-on card... but apart from that, they are excellent bang for the buck. Only downside is they are a bit... BIG. And heavy.
                • SluggerB
                  • Aug 2020
                  • 747
                  • US
                  I played with that idea but my Linux skills are atrocious. But I still haven't completely ruled it out
                  • SluggerB
                    • Aug 2020
                    • 747
                    • US
                    Rec's for an affordable, available AM3+ motherboard? I value stability over raw performance
                    Edit: nvm, just saw the ASRock 970M Pro3 AM3+ is back in stock at newegg for $65. Just ordered it. Pairing that with 32gb of RMA and the best CPU it can support (looks like a
                    Phenom II X6?) should be a big upgrade over what I currently have and keep me trucking on Windows 7 for a long time.
                    • SluggerB
                      • Aug 2020
                      • 747
                      • US
                      Everything finally showed up I should have the time to build in a week or so. I'm going to repurpose my Phenom CPU, HDD's and Power Supply given that chip prices seem to be crazy high right now, the HDD's are less than a year old, and the Power Supply works fine.
                      After this the only component that will be original from this build back in 06(?) will be the CPU cooler
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        ^ Nice.
                        Maybe we will see it in the Post your system thread too when it's done?
                        And yeah, prices do seem to be a bit high right now... which is good - more reasons for people to hold onto and use their old PCs, thus reducing eWaste somewhat.
                        • jm1234
                          Reolink RLC-410-5MP - buck convertor
                          by jm1234
                          it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
                          Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
                          07-14-2025, 04:30 AM
                        • Hondaman
                          Win7 Emulation in Linux
                          by Hondaman
                          If I install Win7 in VirtualBox or KVM, will Windows be tied to that exact hardware? Can I take the VM and move it to another machine at some point without having to re-activate Win7?
                          I bought a replacement board identical to the one Win7 is licensed on. But of course it failed. I have two more identical boards in my basement. Running out of acceptable hardware will not happen for quite a few years, hopefully.
                          But I am looking forward to that day when I cannot find any hardware, and I have to use emulation. Does anyone have experience with this?
                          07-21-2025, 12:46 AM
                        • eccerr0r
                          win7 home iso? can I get 10?
                          by eccerr0r
                          Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
                          So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
                          09-14-2023, 07:35 AM
                        • Dobrowol
                          Dell Latitude 3520 help with bios build/repair
                          by Dobrowol
                          Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                          Steps i done and results:
                          I exported a clean bios from update file via pfs extract.
                          1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                          Result: Dead
                          2. Build clean bios with no changes in ME, new PMC, PCH
                          Result: Dead
                          3. Build old bios with clean ME, new PMC, PCH
                          Result: The same
                          09-22-2023, 02:43 AM
                          ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                          This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                          09-12-2024, 03:28 PM
