LC-B400ATX Power Supply
  • japlytic
    • Oct 2005
    • 2086
    This morning, I decided to check all of the electrolytic capacitors inside my computer. All of the electrolytics on the boards were good, but there was one bulging in the power supply (C23 - 2200uF 10V, with the brand which appears to be "DON" RK series). I decided to replace this with a 3300uF 10V Rubycon unit, and as a good measure, added C28 and C22 (both 3300uF 10V Rubycon units, which were not originally fitted), as well as replacing C1 and C2 (both 470uF 200V Gincon GR series units) with Nippon Chemi-Con units. C1 and C2 were not bulging, but were replaced with better quality units as a good measure.
    Fortunately, I did this before it was too late!
    Does anyone know about the Gincon brand of electrolytic capacitors?
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: LC-B400ATX Power Supply
    Haven't heard of Gincon or DON brands. If that's supposed to be rated at 400W - guessing, based on the model # - I'd be really careful of cooling. Those heatsinks look pretty insubstantial for 400W.
    PeteS in CA
    • gg1978
      • Dec 2004
      • 431
      That's a Deer Power supply.. Given their tendency to selfdestruct, and take the parts attached to them with it, i'd highly recommend replacing it..
      • japlytic
        • Oct 2005
        • 2086
        I decided to upgrade all of the electrolytics in this supply (board space permitting), as well replacing the voltage reference device (PJ431) with a better quality TL431 unit.
        ORIGINAL UPGRADED RAIL/USE
        C1 470uF 200V Same value Primary filter
        C2 470uF 200V Same value Primary filter
        C5 2.2uF 50V Same value Feedback
        C6 2.2uF 50V Same value Feedback
        C8 22uF 50V
        C11 2.2uF 50V Same value Voltage Reference
        C13 Not fitted 1000uF 10V +5V Standby
        C15 47uF 50V Same value
        C17 1uF 50V Same value
        C18 1000uF 10V Same value +5V Standby
        C21 47uF 50V Same value
        C22 Not fitted 3300uF 10V +3.3V
        C23 2200uF 10V 3300uF 10V +3.3V
        C25 2200uF 10V 3300uF 10V +5V
        C27 2200uF 16V 4700uF 16V +12V
        C28 Not fitted 3300uF 10V +5V
        C29 470uF 16V 1000uF 10V -5V
        C31 0.22uF 50V Polyester
        C32 470uF 16V 1000uF 16V -12V
        Rail Filtering Capacitance Comparison
        HIGH-POWER OUTPUTS
        ORIGINAL UPGRADED % INCREASE
        +3.3V 2200uF 6600uF 200
        +5V 2200uF 6600uF 200
        +12V 2200uF 4700uF 113
        LOW-POWER OUTPUTS
        ORIGINAL UPGRADED % EXTRA
        -5V 470uF 1000uF 112
        +5V 470uF 1000uF 112
        +5VSB 1000uF 2000uF 100
        • AK0R
          • Mar 2005
          • 204
          Two questions:
          1. How does the cost of your upgrades compare to the cost of a new, high-quality power supply?
          Low cost: Why won't the manufacturers give us, the consumers, good stuff?
          High cost: And people wonder why these are called "disposable" goods!
          2. How well does it work, compared to before?
          • Rainbow
            • Aug 2005
            • 1375
            C8 is probably the cap-of-death. Just for fun, check the old one (if you still have it) using a meter - if it's crap, it might already have decreased value.
            • japlytic
              • Oct 2005
              • 2086
              C8 is the capacitor connected between the cathode and reference pins of the programmable voltage reference device, which affects feedback. I would replace all of the low-value capacitors anyway.
              • japlytic
                • Oct 2005
                • 2086
                When I searched for a LC-B400ATX, I found a similar power supply schematic on http://narod.yandex.ru/100.xhtml?ele...Y-B200-ATX.zip
                U1 is an optocoupler (It is a PC817 in mine). The "2003" device seems to be a bit strange, and it is apparantely proprietory to the manufactures of this supply. Good ones have a SMPS controller from a well-known manufacturer (eg. TL494).
                I think I might scrap this apparantely fake power supply (should I? ), and use the SMPS controller in a bench power supply (If I know how to wire it up). Good parts from it would also be salvaged for other projects.
                • japlytic
                  • Oct 2005
                  • 2086
                  Update: Found a very similar one on http://www.eserviceinfo.com/download.../L&C_400W.html
                  The SMPS controller is a DR0813 (another proprietory chip).
                  Should I still scrap the LC-B400ATX power supply?
                  • arneson
                    • Sep 2005
                    • 1267
                    japlytic, Thanx , Ive been hoping to find this info.
                    Especially the first one.
                    Very well drawn.
                    Jim
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      the chip with the odd number is usually something standard remarked.
                      often a poor job grinding the old number gives it away or you can look at the design and figure out what it is.why do they bother?
                      all they did was build some reference design anyway.
                      • gg1978
                        • Dec 2004
                        • 431
                        :all they did was build some reference design anyway.:
                        Hahaha.. Yeah, i suppose they did do that, then rip out half the toroids, filter caps, and use shitty components. At least every single Deer/LC/Foxlink/etc PSU i've seen has had missing parts, especially in the output section..
                        Best constructed PSU i've ever seen are Delta's.. I've got a pair of 2000 vintage DPS300BB's, with huge transformers, Nichicon caps, and enough toroids to make it weigh at least double of a cough "300W" PSU from the shit manufacturers..
                        • Rainbow
                          • Aug 2005
                          • 1375
                          Yes, you can roughly compare PSU quality by weight (provided that they don't have PFC - because passive PFC inductor can be heavy). If you have 2 PSUs and you don't know which one to choose, just choose the heavier one
                          This often works with other devices - CRT monitors, keyboards, optical drives...
                          • Newbie2
                            • Sep 2005
                            • 885
                            Thanks for the power supply schematic japlytic! I was looking for that for a very long time.
                            My gaming PC:
                            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                            ASUS M4A77TD AMD 770 AM3 Motherboard
                            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                            ASUS Xonar DG 5.1 Channel PCI sound card
                            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                            Antec Three Hundred Mid-Tower Case
                            Microsoft Windows 10 Pro 64-bit
                            Microsoft Windows 7 Ultimate SP1 64-bit
                            • linuxguru
                              • Apr 2005
                              • 1564
                              > When I searched for a LC-B400ATX, I found a similar power supply schematic on http://narod.yandex.ru/100.xhtml?el..._Y-B200-ATX.zip
                              Nicely drawn schematic, but there are some minor errors (no doubt, it is a reverse-engineered
                              schematic). For instance, the polarity of the lower winding of T2.2 is inverted (Q1 needs to be conducting when Q2 is off, and vice-versa, in a push-pull half-bridge topology).
                              In this case, the polarity is not a problem (since the transformer can only be inserted in
                              one orientation physically) - but it would be a problem for capacitors. Please check the schematic against the PCB very carefully before placing too much reliance on it.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • shamsudeen
                                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                by shamsudeen
                                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                07-19-2025, 07:14 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
