Car radio stopped working
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Strange... With the hot weather, suddenly my car's broadcast receiver stopped working. It had been working fine. I hear noise only when I turn up the volume all the way. I can "tune" but the noise silencer silences the noise after a second...
    Cassette player still works.
    Antenna failure, frontend RF amplifier failure, dunno yet, I haven't pulled the head unit from the vehicle yet...
    Hmm.
    • 31218
    Re: Car radio stopped working
    maybe there is nothing on air?
    or your antenna is unplugged or damaged
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Damn. wasn't as simple as a disconnected antenna. Wonder if this 1995 radio has electronic or switch switching of audio vs cassette...
      Wonder how much effort I should try to fix this or find another one from a boneyard.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Ugh. Custom components, this is going nowhere fast. Some people have reported reflowing repairing the radios but I chalk that up to dumb luck... heck I wonder if I buttoned the radio back up without doing anything, it'd start working again...
        • petehall347
          • Jan 2015
          • 4440
          • United Kingdom
          check antenna connections . might have corrosion where it connects to the body .
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            AM works, FM does not work. Tuner problem. Has COB's. Probably lost cause.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Thinking for now I should jury rig a line-in so I can at least use the PA, but probably will need to replace. Now figuring out where to tap in...
                • 31218
                is it DIN format, or some custom face shape?
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Almost DIN but not quite... About 1.5 DIN. Front face is not part of the panel, at least, but the unit is attached at the front so the mounting kit needs to have that adapter else nowhere to attach it to the vehicle.
                  • redwire
                    • Dec 2010
                    • 3912
                    Does it have an active antenna? I have seen these get water in them and then croak.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      I don't think I saw the term COB before when used with a radio. What's that?
                      I can think of COF, for chip-on-film, which can be miserable!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Same as the usual definition - chip on board, one of the daughterboards has two dies (dice?) black epoxied onto the board itself...
                        ... if someone thinks of sanding off tops of ICs, try identifying ICs that are epoxied on the board!
                        Active antenna? Don't know, don't think I have an RF preamp. The troubleshooting guide in the service manual says "exchange radio" ...
                          • 31218
                          so does it have a real antenna, or is it using the screen heater or a tiny fin?
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Real antenna. Not even a power antenna, just a real antenna.
                            I don't think I'd be getting AM stations if the antenna was borked, so I have to rule out the antenna...
                            • petehall347
                              • Jan 2015
                              • 4440
                              • United Kingdom
                              you might get AM ok even with marginal antenna .. i have been in plenty of cars that only get AM because of it . FM likes a ground connection . well thats what i find .
                              • redwire
                                • Dec 2010
                                • 3912
                                Active antenna pre-amps can get water in or a bad connection on power, and almost a total loss of FM signal. AM makes it through anything.
                                Or the coax can get water in it, try ohmmeter it.
                                In the shop we just poked a jumper on the antenna jack to see what happens.
                                People put in aftermarket radios and the antenna stops working mysteriously. They forget to keep power to the antenna or bias-tee, which the stock radio provided.
                                In car radios, I find it's almost always broken solder joints. Tapping the pc boards to flush that out. Unless lightning/static zapped the front-end hard, but there's usually a gas-tube there.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Most curious. Tuned to a known FM station I poked the antenna wire with a metal wire and... well... still dead.
                                  ... however I hear popping...
                                  HMM...
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Well, today's debug session was kind of annoying.
                                    I had broken the power output lead in my bench PSU, and was wondering why my radio didn't work at all on my bench. Finally tried shorting the output cable expecting the current to go up... it didn't. Alligator clip wire was found to be broken.
                                    So I needed to resolder. My 100W solder gun is now taking forever to heat up... well, guess what, I need a new tip for it. Grr. Well, I just let it heat up however slowly it does and finally was able to resolder the alligator clip to the wire.
                                    Now my radio powers up on the bench. With the pinout in hand I probed the pins... Glad I have a 300MHz scope (or too lazy to get the frequency counter set up) and confirmed the local oscillator is dead or at least it doesn't trigger the rest of the PLL circuit to work properly. Since the LO is on the COB TEMIC module, debug stops here, need to locate another TEMIC module to repair the radio.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      COB Hell.
                                      Yes there's more components on the other side, though covered by the shield.
                                        • 31218
                                        pull the shield.
                                        just from that picture i think it may recover just with a good fluxing and a re-heat of each joint.
                                        though from experience with sattelite tuners i would test the semiconductors - they are probably on the edge of there rating
                                        • flat-earther
                                          HP F4180 stopped working please help troubleshoot
                                          by flat-earther
                                          I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
                                          So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
                                          I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
                                          I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
                                          I ran HP Print and Scan...
                                          05-11-2025, 02:21 AM
                                        • mikey5791
                                          Sony CFS-5000S radio cassette player no FM reception
                                          by mikey5791
                                          Hi forum members,
                                          In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                                          Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                                          I opened the casing inside and checked for any dry solder, burned component or loose wires...
                                          02-24-2023, 03:48 AM
                                        • thaphatmaster
                                          Dremel Li-Ion Charger Stopped Working
                                          by thaphatmaster
                                          This is my dremel charger for one of the Dremel / Bosch 10.8v (3s1p) Li-Ion packs. There are many like it, but this one is broken.
                                          It stopped responding the other day. No light when a battery is inserted, no voltage at the output when tested.
                                          The dremel itself and its battery are fine and working.
                                          Looking online, many people just replace this type of charger with an Aliexpress version. However most of the through hole components look straightforward enough to replace if they are broken.
                                          I'll do some basic poking about (continuity checks etc)...
                                          01-29-2025, 10:39 AM
                                        • samstown
                                          Startech - 12 V Sata HDD Docking stopped working - Need help to identify an IC
                                          by samstown
                                          Hello folks,
                                          One day my Startech HDD SATA docking stopped working, instead of buying a new one I want to repair it. I've measure PCB and I think U10 is a mosfet and the culprit but I don't know what chip to order to repalce it.
                                          Sam...
                                          01-27-2024, 05:22 AM
                                        • Roman555
                                          Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
                                          by Roman555
                                          Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
                                          • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
                                          • USB stick with MS-DOS can be loaded via F8 boot menu;
                                          • Other OSes won't load - hangs or goes reboot;
                                          • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
                                          • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
                                          What I've already done and it hasn't helped:
                                          • Cleared CMOS many times;
                                          • Flashed different versions of BIOS in a CH341 programmer;
                                          • Updated
                                          01-18-2024, 06:26 AM
