Car radio stopped working
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Car radio stopped working
    find two cheap single channel pots, use a rubber band to gang them? =\
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      speaking of balance controls, I have one line powered desktop radio that solved the balance for debug solution by ganging two pots, one for left and one for right, by default (friction) but you can rotate the two pots separately for debug or if the broadcast/tape was sourcing weird...
      interesting if not unconventional, though this unit is ancient, probably 40 year old design.
        • 31015
        you could actually use a rotary encoder and a couple of digital-pot chips.
        i use those chips sometimes - they are very interesting.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          That'd infinitely increase the cost of the radio/repair!
          Then again I probably already did so already by putting in a 220Ω ⅛W resistor to fix that one nonfunctional channel... fortunately it was a salvage resistor so maybe not so bad.
          • jimku4aa
            • Jan 2022
            • 5
            eccerr0r,
            I had found your thread while cruising the net for some info on the Temic FM tuner module. Since the last post was only 5 weeks ago, I thought I might ask: Are you still working on your car radio (not given up on it)?
            I might be able to help with a donor unit that I have as a spare.
            Jim
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Thanks, I'm good with it now, I found a "parts unit" radio that had apparently has a good TEMIC module in it. I ended up repairing the "parts unit" as the original unit needing repairs had been severely damaged from the accident. Still no cassette player, but the radio/amplifier works fine and that's good enough for now.
              Not sure why but I'm still holding onto the old tape mechanism... unfortunately cannot use with the "parts unit" radio.
              Old unit:
              busted TEMIC module
              busted volume control (due to accidental fall)
              tape player works (with bad caps...)
              Parts unit:
              TEMIC module along with the rest of the broadcast receiver electronics works
              Bad tape player (tape player is completely jammed)
              one audio channel broken (I was able to fix it, tracked down one teeny surface mount resistor)
              doesn't totally fit (jury rigged it to fit)
              • jimku4aa
                • Jan 2022
                • 5
                Ok. I have a Chrysler "RAS" original factory radio from a 1994 Dodge Dakota that is fully functional, for which I have absolutely no use. It's an AM/FM unit with cassette. Price is right, too: $0.
                I worked for Chrysler Huntsville Electronics from 1985 to 2001, originally in automotive tester section but moved over to component test in 1998. I was assigned to work up a test program on the automated test equipment to verify the Temic FM tuner units. Seemed that the Temics had a very high failure rate and was probably the #1 failure item on the late 90's Huntsville radios. Big important project, I was told. But before I could begin implementation of the test program, I received my pink slip (at my 15-1/2 year anniversary, to the day! ). I'm now drawing my pension from Chrysler, but kinda wished that I could have tackled that Temic project. Looked quite interesting, especially since I'm now doing a lot of RF stuff at home.
                Best wishes for your success on your ongoing radio project!
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Ah cool yeah, I had to dumpster dive that "parts unit" pretty much. I spied a craigslist ad with something that looked similar to what I had and went ahead to snap it up. I guess it just costed gas.
                  That's pretty awful, seems those TEMIC units are just awful. If only you had remained to find a way to weed out those bad units! Then again I can only be about 80% sure that it was my TEMIC unit that failed due to the lack of documentation, alas I think the cursory spec sheets were just about sufficient (I did not detect the OSC or MPX output on my Tek2465 though I think I did detect the control voltage IIRC.)
                  I still sort of wonder what specifically failed - was it diebond or the COB itself or something else... without further information about the guts of the module it's kind of hard to get much further. That and the special sauce part numbers that car manufacturers like to put on their ICs to baffle the DIY repairers.
                  What made you search for TEMIC information? Sounds like you know a lot more of these things than us mere mortals...
                  • jimku4aa
                    • Jan 2022
                    • 5
                    I was looking for some odd RF parts to play with to kill some time in my garage/workshop. Pulled that RAS radio out of a bin with other car radios I had. Opened the radio then realized that it was a unit with the Temic FM tuner and a TDK (?) AM tuner. Not much RF fun there.
                    I might have been the Temic guru at Chrysler had I stayed on and completed the test program. That was 20 years ago, and I pitched any documents that I might have retained long ago. I've got some double-balanced mixers coming in next week from Ebay, but that's next week! The Temic unit is basically a black box you put signals and power in and get audio out. No fun for an experimenter.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Yes very true, alas it makes thing a lot easier in terms of shielding and its sensitivity/selectivity is fairly good compared to any homemade devices. Before I acquired the parts radio, I put in another car radio, was only a 1DIN instead of a 1.5DIN. This radio on the other hand was more of a discrete receiver - has components everywhere. Didn't spend the time investigating it but was nothing like the TEMIC - more like my old Heathkit AR-1219's design - though it should be PLL based (it has digital tuning after all) like the TEMIC/Chrysler radio, and not an open loop drifty LO like the Heathkit.
                      Alas that radio's sensitivity (and selectivity) is nowhere near the TEMIC. There are stations it can't pick up as well as the TEMIC and can even hear bleedover from nearby stations. Ugh. Well the main reason why I despised this interim receiver was that it was 1DIN and didn't really fit, not to mention it was a single ended versus the Chrysler radio that had a higher power bridged output.
                      • jimku4aa
                        • Jan 2022
                        • 5
                        No doubt about it, the OEM Chrysler radios were top-of-the-line for sensitivity, selectivity, and audio. I was quite proud of the radios we built in Huntsville. Only reason I pulled the OEM radio in my '03 Dodge Dakota was to gain the hands-free features of a Bluetooth radio. Took out the 1.5 DIN, put in a double-DIN. Now THAT was a job!
                        • flat-earther
                          HP F4180 stopped working please help troubleshoot
                          by flat-earther
                          I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
                          So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
                          I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
                          I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
                          I ran HP Print and Scan...
                          05-11-2025, 02:21 AM
                        • mikey5791
                          Sony CFS-5000S radio cassette player no FM reception
                          by mikey5791
                          Hi forum members,
                          In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                          Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                          I opened the casing inside and checked for any dry solder, burned component or loose wires...
                          02-24-2023, 03:48 AM
                        • thaphatmaster
                          Dremel Li-Ion Charger Stopped Working
                          by thaphatmaster
                          This is my dremel charger for one of the Dremel / Bosch 10.8v (3s1p) Li-Ion packs. There are many like it, but this one is broken.
                          It stopped responding the other day. No light when a battery is inserted, no voltage at the output when tested.
                          The dremel itself and its battery are fine and working.
                          Looking online, many people just replace this type of charger with an Aliexpress version. However most of the through hole components look straightforward enough to replace if they are broken.
                          I'll do some basic poking about (continuity checks etc)...
                          01-29-2025, 10:39 AM
                        • samstown
                          Startech - 12 V Sata HDD Docking stopped working - Need help to identify an IC
                          by samstown
                          Hello folks,
                          One day my Startech HDD SATA docking stopped working, instead of buying a new one I want to repair it. I've measure PCB and I think U10 is a mosfet and the culprit but I don't know what chip to order to repalce it.
                          Sam...
                          01-27-2024, 05:22 AM
                        • Roman555
                          Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
                          by Roman555
                          Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
                          • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
                          • USB stick with MS-DOS can be loaded via F8 boot menu;
                          • Other OSes won't load - hangs or goes reboot;
                          • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
                          • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
                          What I've already done and it hasn't helped:
                          • Cleared CMOS many times;
                          • Flashed different versions of BIOS in a CH341 programmer;
                          • Updated
                          01-18-2024, 06:26 AM
