Hi all.
I am about to investigate a issue with that Sony KDL-43W805C. So, the tv is working except the picture. When i switch it on the backlight come on and the picture is going trough different states - with lanes, colors etc:
I read some threads that it could be software issue and need to upgrade the software but i could not do that following these steps:
and
I think i did factory reset using Vol down and Power button combination because every time when i switch it on now i can hear some music and i believe it is coming from the welcome screen. I am not experienced in this but it sounds like T-CON board issue. Anyway i am going to open that TV in the next days but just wanted to hear some more suggestion and will be glad if you give me some advises.
Thank you!
1. Download the SOFTWARE corresponding to your REGION and LANGUAGE from the official SONY SUPPORT page
2. Follow the instructions to save it in USB
3. Connect and turn on the TV, wait for screen image to go
4. Connect the USB to port number 1
5. Press "HOME" on the REMOTE CONTROL
6. Press UP ARROW once and then ENTER (CENTER BUTTON)
7. Press DOWN ARROW once and then ENTER
8. Press DOWN ARROW three times and then ENTER
9. Press only ENTER again
10. Press LEFT ARROW once and then ENTER
11. Wait about 2 minutes and press LEFT ARROW again once and then ENTER
12. The power indicator LED should start flashing amber, that indicates that the update started if it does not flash wait a few more minutes and press LEFT ARROW again once and then ENTER ...
3. With the TV off in standby... Insert USB pen drive to USB port of TV
4. Pull Out the AC plug and wait 10 second (considering the charge of AC adaptor)
5. Press and hold the side Power Key for 5 seconds and re-insert the AC plug at the same time
6. After 20-30 seconds, the LED is turn to Amber and blink
LED blinking indicates “Under SW Update”
Thank you!
