How to test tiny black resisters on lcd panel board
  • Gasvan
    • Feb 2020
    • 17
    Just wondering if i should be looking for continuity here is a pic of what im talking about
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8289
    Re: How to test tiny black resisters on lcd panel board
    these dont have any resistance.
    • Gasvan
      • Feb 2020
      • 17
      Ty but What could be the cause of this problem i have
      • Gasvan
        • Feb 2020
        • 17
        I tested all the caps non are shorted out although when i tested some caps in ohms some started reading in the negative then slowly went up to over 150 ohms is that bad.
          https://www.badcaps.net/forum/attach...8&d=1581720168'
          What does it look like with some kind of images on the screen instead of the User OSD?
          • Gasvan
            • Feb 2020
            • 17
            When i plug in a video source to the hdmi the picture is gean red and laggy like overlapping. I ordered a tcon board put in in with no change.
              We need to see what the image looks like on the screen, your description does not mean much.
              We do not even know the make and model of the TV.
              We also need the pictures of the whole backside of the the TV showing all the boards.
              It is hard to help since we do not have the TV right in front of us to look at.
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
