Strange Memtest screen
  • c_hegge
    • Sep 2009
    • 5219
    Note how far memtest is into the test in this picture
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Strange Memtest screen
    Mine goes to around 160% for each pass
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      It does that. Nothing to worry about.
      [Total guess]
      I think that % is based on the estimated time to finish.
      If actual time is slower than estimated time then that number goes over 100%.
      Mann-Made Global Warming.
      - Dr Seuss
      • JunkmanJimbo
        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
        by JunkmanJimbo
        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
        Please help. Thanks in advance!
        08-12-2025, 11:45 AM
      • reformatt
        Macbook Air M2 A2681 Kernel panics after screen replacement
        by reformatt
        Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
        It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • ipatch
        ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
        by ipatch
        i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
        08-24-2024, 02:36 PM
