Panasonic TX-48CX400B Only backlight no picture
  • Fixing222
    • May 2017
    • 67
    Sound works and screen is illuminated the back light but no picture.
    The blink code when i turn on is 14 or 15 i think it is one of them im not sure
  • nomoresonys
    • 12331
    • U.S.
    Re: Panasonic TX-48CX400B Only backlight no picture
    Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on. So we can see all the voltages and what they are doing. example in second link below if needed.
    • Fixing222
      • May 2017
      • 67
      So it was from top of tv way to bottom
      11.98
      0
      0
      0
      1
      0
      TV ON
      11
      0
      2.6
      3.2
      0
      24.94
      I'm not sure what you mean by pin number
      • nomoresonys
        • 12331
        • U.S.
        Ok, I see you have one of those vestel powerboards, a lot of them don't seem to have the voltages marked on them, I better let one of the vestel pros help you. We don't see to many of those on this side of the pond.
        • Fixing222
          • May 2017
          • 67
          Ok yeah it's not so pretty as others inside and not so easy hopefully incase it mattets to anyone I typed the board in and the part cn4 and got this
          Image attaches
          And the service manual/circuit diagram attached
          • diif
            • Feb 2014
            • 6978
            • England
            Please stop posting pictures inline. Press Go Advanced then use the paper clip icon.
            • Fixing222
              • May 2017
              • 67
              Ok thanks for notifying me will do , yes take up lots of space sorry
              • Fixing222
                • May 2017
                • 67
                After changing T-von and mainbiard it was none of them so maybe powerboard
                  Did you already try having ribbon cable between LCD panel and the T-CON board connected one at a time to see what you will get on the screen?
                  • Fixing222
                    • May 2017
                    • 67
                    Sorry not had much time to open it up but just got round to it, same thing. That was a good idea so this rules out the two tab boards (Driver boards) attached to the LCD if no display or could it still cause no display or a short just wondering
                      Checking Voltages on T-CON board test points will be next, I.E. VDD, VGH, VGL, etc.
                      • Fixing222
                        • May 2017
                        • 67
                        Only have VCC multiple times but will check all of those.
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
                        • Bazfletch3
                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                          by Bazfletch3
                          Hi all
                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                          From there I envisaged that the backlighting wasn't working, however...
                          01-08-2024, 10:18 PM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
