ZBook 15 bios dump
  • ZBooker
    • Dec 2018
    • 13
    ZBook 15 bios dump
    Hey,
    I've made a new bios dump of ZBook 15 with CH341A programmer but only software v1.18 was able to verify it....v1.29,30,34 all fail.
    Can someone tell me if dump is ok or corrupted?
    Thanks!
    ZBooker
    • 22084
    Re: ZBook 15 bios dump
    It looks ok. Are you using a clip ? , if so ,desolder the bios and use a socket for better results.
    • ZBooker
      • Dec 2018
      • 13
      Hey SMDFlea,
      thanks for your help. I was able to pull a backup using flashrom and a CH341A + Clip. I was able to erase/flash the chip again and works as expected. Dump is attached.
      As this dump is okay, do you have any advice how to unlock MPM? I have replaced my board, set DMI info, locked MPM, BUT forgot to set intel AMT. Machine is now in committed state.
      Is it possible to pull the ME region from a different file to my dump or will I brick the whole thing?
      Thank you
        • 22084
        The pics are too smal to see. Download/extract the first attatchment in this thread: https://www.badcaps.net/forum/showthread.php?t=69204 "Manufacture Programming Mode in Unlock mode"
        EDIT: look at the jpg image in the folder original.jpeg
        • ZBooker
          • Dec 2018
          • 13
          Oh Im sorry, pictures now attached.
          Ive tried that MPM file and get/set but it didnt work. It states it was successfully written to bios but MPM is still locked on reboot.
            • 22084
            Your bios version is quite old. Check the latest bios https://support.hp.com/gb-en/drivers...tation/5387800
            • ZBooker
              • Dec 2018
              • 13
              Are you sure? System shows me L70 Ver. 1.44 which is also listed as latest on HP website. Did I misunderstand you?
              • ZBooker
                • Dec 2018
                • 13
                Im a step further: I replaced the BIOS REGION with one from stock HP update which results in a MPM unlock - BUT on first boot I receive the message that "EC mismatch with configuration - going to restore system information"... any ideas?
                  • 22084
                  Try this bios .
                  • ZBooker
                    • Dec 2018
                    • 13
                    Try this bios .
                    You Sir are a genius! Flashed the image - "not committed state" was gone right away - MPM was unlocked and locked itself. Runs perfect!
                    You have used flash image tool to clean ME?
                    Thank you!
                      • 22084
                      Nope,certainly not a genius , if i had half a brain i wouldn`t have got into laptop repair as a living.
                      Used FIT to add a new ME .
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        long live that comment and its creator... i feel the same way
                        Im Back... sort of...
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • zlr8r
                          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                          by zlr8r
                          Greetings
                          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                          Serial Number: 5CG3202C16
                          Product #/SKU: 739P0AV
                          CT Number: PRTUE00WBI30YX
                          Description: HP ZBook Firefly 14 inch G10
                          BuildID: 23WWWGAZ602#SABU#DABU
                          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                          MAC address not found.
                          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                          10-28-2025, 01:56 PM
                        • mkdj
                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                          by mkdj
                          Dear all,
                          I have a ASUS ZenBook UX480F with the following symptoms:
                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                          10-19-2025, 04:41 AM
                        • Habble7
                          I need a BIOS dump for the Samsung S49CG934SU monitor
                          by Habble7
                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                          Suspected Cause:
                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
