sony xbr65x850C - pure evil
  • itelite
    • Aug 2016
    • 124
    fighting a sony xbr65x850C since the beginning of november.
    Original issue - no power
    replaced power supply
    power but scrambled looking HDMI
    replaced main board
    mainboard was actully for the 55" version (identical) and powered on to blinking yellow and green ( i think)
    took EMMC from old main board, read on EMMC reader, made backup of both new and old EMMC (so we know for sure they are both readable)
    reballed and transferred to new main board. Quite certain no issue in the physical swap, but who knows.
    back to no power.
    Standby is there, power VCC and VVCq to EMMC is there. No shorts on EMMC as far as i can tell from the external components. (CMD CLK DAT0)
    Was about to start soldering wires for ISP to make sure my EMMC swap went well, and decided to test the power supply.
    External 3.3 supply connected to power_on BL_on tcon_on
    tcon voltage 12V
    BL voltage 93V on out- 222V on out+ with ground plane ground reference.
    Backlight does not light up
    dc dimmer to 3.3v or ground changes nothing. Same for PWM dimmer.
    All voltages as the connector seem to check out
    I am fully willing to accept the main issue lies in the EMMC swap and the contents there of, and i should be able to work through it, but this backlight issue makes zero sense to me. Could a crappy backlight have been my "power" issue all along? Any way to bypass protection if there is any?
    No light on the optical audio, and no 5 volts on USB, but main IC heatsinks are getting warm. So somthing is happening. A debug UART would be excellent, but i don't see anything obvious.
    any ideas or where to go from here?
  • nomoresonys
    • 12330
    • U.S.
    Re: sony xbr65x850C - pure evil
    "blinking yellow and green ( i think)" Did you try a firmware update/reapply at that point right there?
    • itelite
      • Aug 2016
      • 124
      I did not. It didnt occur to me that it would take 65" firmware via the USB method. It would not be possible at that time to update via the system menu, but i assuming you are alluding to an alternate method.
      I suppose i can flash the 55" backup image i made to the installed EMMC if there is any benefit to doing so.
        "power but scrambled looking HDMI" So after replacing the power supply board, the TV will come on but with scrambling pictures, so you replace the main board but now you have no power,no backlights, no lights on optical, etc.
        So what happen if you put the original main board back in?
        • nomoresonys
          • 12330
          • U.S.
          Yes, USB method.
          • itelite
            • Aug 2016
            • 124
            Originally posted by budm
            "power but scrambled looking HDMI" So after replacing the power supply board, the TV will come on but with scrambling pictures, so you replace the main board but now you have no backlights, no lights on optical, etc.
            Old board has no EMMC currently since i swapped it to the new board. I suppose i can swap the EMMC back over.
            • nomoresonys
              • 12330
              • U.S.
              https://www.sony.com/electronics/sup...ry=+xbr65x850C
              • itelite
                • Aug 2016
                • 124
                downloading firmware now
                • nomoresonys
                  • 12330
                  • U.S.
                  Might want to go with the 5.417, the other one didnt show up in the applicable models, no C on the end, dont know if it would matter or not.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4538
                    • Italy - Milan
                    Oh God, you made a JAM!
                    Swapping eMMC it's an incredible waste of time...
                    You had to swap only eeproms, and if are sop8 you can also do in 5mins. with clip...
                    • nomoresonys
                      • 12330
                      • U.S.
                      Any progress?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4538
                        • Italy - Milan
                        Warning! This beast of tv can have a very tricky situation about the screen, i remember a thread of Freakaftr8 with same set, check it, that "blinking yellow and green" remeber me its thread, possible screen damage (?)..
                        • EazyBone
                          Sony 55/65 A1E sony OLEDs EMMC dumps
                          by EazyBone
                          Does anyone know where one would get these dumps for EMMC? I have two 55/65 A1E sony OLEDs that likely need new EMMC chips but I do not have the file.
                          Is there a database or website you use to find these?
                          lotas anything in the Russian space websites you know of also?
                          10-31-2025, 06:22 PM
                        • saghi88
                          i need eMMC Dump for Sony KDL-55W805C
                          by saghi88
                          The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
                          This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
                          does anyone have the EMMC dump file?
                          Model: Sony KDL-55W805C
                          Mainboard: 1-980-805-31
                          EMMC: SK HYNIX H26M52103FMR
                          Display-Panel: T550HVF06.0
                          07-04-2025, 02:11 PM
                        • mhd bero
                          Sony KD-65XD8505 EMMC NEED
                          by mhd bero
                          Hi.
                          I'm searching for an eMMC dump for Sony KD-65XD8505
                          Motherboard: 1-980-832-11
                          THE TV NO BOOTING HE HAVE 8 TIME RED LED BLINKING I THINK EMMC DUMP FILE IS DAMAGE.
                          Thank you.
                          09-09-2025, 09:31 AM
                        • 5m44p1x
                          Looking for Sony KD-55X750F EMMC dump
                          by 5m44p1x
                          The TV falls into boot loop several minutes or hours after power on, I'm thinking it's the EMMC issue, and want to have a try from there. Is there anyone who got this one and willing to share it with me? Million thanks!
                          Model: Sony KD-55X750F
                          Mainboard: 1-982-454-11
                          EMMC: SK HYNIX H26M52208FPR
                          08-01-2025, 12:26 AM
                        • Morosan Dimitrie
                          Sony KDL 55W-955B Sony EMMC dump search :)
                          by Morosan Dimitrie
                          Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
                          KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,...
                          06-08-2024, 04:13 PM
