Sony KDL 55W-955B Sony EMMC dump search :)
  • Morosan Dimitrie
    • Jun 2024
    • 7
    Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
    KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B, KDL-50W828B, KDL-55W828B, KDL-55W829B, KDL-50W829B, KDL-50W817B, KDL-55W817B, KDL-50W705B, KDL-50W706B, KDL-40W705C, KDL-32W705C, KDL-48W705C, KD-85X9505B, KD-65X9505B, KD-79X9005B, KD-65X9005B, KD-55X9005B, KD-70X8505B, KD-65X8505B, KD-55X8505B, KD-49X8505B
    Please maybe someone has a dump from those model so I can try. If it helps to motherboard code is 1-889-347-11.
    Thank you in advance!​
  • Diah
    • Feb 2013
    • 6677
    why you suspect the emmc... sony W series are known of BGA issue at Vision Soc
    • Morosan Dimitrie
      • Jun 2024
      • 7
      Because I check the power supply and is sending power, I tried to reflow the emmc without succes same thing. I check for short circuit whole motherboard and everything ok and when I check the emmc information from it is corrupted.
      • Morosan Dimitrie
        • Jun 2024
        • 7
        I hope maybe I can find someone to help me with a copy from a working emmc to try it 😁
        • lotas
          • Jan 2016
          • 5299
          • Russia
          Someone else's firmware does not work on this chassis, you will get error "3". These boards have defective memory chips (DDR).
          • lotas
            • Jan 2016
            • 5299
            • Russia
            If you want, try it.
            Dump was read by the UFPI programmer, rename the files to suit your programmer (RT809H).​
            https://disk.yandex.ru/d/BD76IPmmBNiWLw
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4700
              • Italy - Milan
              emmc reballing is required i guess.. if also corrupted files also emmc rewrite..
              KDL-55W955B
              • Morosan Dimitrie
                • Jun 2024
                • 7
                Hy guys. I change the EMMC with a new one and put the dump from lotas on the new EMMC and now I have 3 red led blinks. Before was no light present no blinks, from what I search on internet I should update the firmaware? Thanks for all the help!
                • lotas
                  • Jan 2016
                  • 5299
                  • Russia
                  I wrote above that someone else’s dump will not help you, you will get error 3 (on this chassis), and that’s how it happened. In this chassis, dump is encrypted and linked to the processor ID...
                  • Morosan Dimitrie
                    • Jun 2024
                    • 7
                    And there is no chance of fixing some how this error ?
                    • lotas
                      • Jan 2016
                      • 5299
                      • Russia
                      Look for a donor (motherboard).
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4700
                        • Italy - Milan
                        there is a little chance, as i have said, that original emmc is ok, but you like others does not trust me..
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8640
                          You should have first figured out if there is data flowing between D0 and the other data lines between the EMMC and the main processor. It will tell you if you got a bad EMMC or bad firmware.
                          • Morosan Dimitrie
                            • Jun 2024
                            • 7
                            How can I check this ? With an osciloscope to see if exist a signal ?
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8640
                              Yes.
                              • Morosan Dimitrie
                                • Jun 2024
                                • 7
                                Hello guys I m back again, from what I found on Internet I see that for this model sony modify the EMMC to work on the enhanced mode which now I understand why It was showing me half of the capacity. I ordered a stencil to fix back the bga ball of the old EMMC and I will come back with an update.
                                • BigPete
                                  Panasonic LED TV Dead after EMMC dump
                                  by BigPete
                                  I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
                                  The dump was successful and the program finished without errors.
                                  I used a XGecu T48 to do the dump.
                                  I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
                                  One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
                                  I also shorted out the crystal of the adjoining ECU together and at one...
                                  03-15-2026, 03:08 AM
                                • saghi88
                                  i need eMMC Dump for Sony KDL-55W805C
                                  by saghi88
                                  The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
                                  This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
                                  does anyone have the EMMC dump file?
                                  Model: Sony KDL-55W805C
                                  Mainboard: 1-980-805-31
                                  EMMC: SK HYNIX H26M52103FMR
                                  Display-Panel: T550HVF06.0
                                  07-04-2025, 02:11 PM
                                • 5m44p1x
                                  Looking for Sony KD-55X750F EMMC dump
                                  by 5m44p1x
                                  The TV falls into boot loop several minutes or hours after power on, I'm thinking it's the EMMC issue, and want to have a try from there. Is there anyone who got this one and willing to share it with me? Million thanks!
                                  Model: Sony KD-55X750F
                                  Mainboard: 1-982-454-11
                                  EMMC: SK HYNIX H26M52208FPR
                                  08-01-2025, 12:26 AM
                                • D1964
                                  Sony KDL46w905A EMMC dump
                                  by D1964
                                  Hi Can anyone supply a EMMC dump for the above model please
                                  10-05-2025, 08:11 AM
                                • YasaCh
                                  Help me my brothers find a dump for SONY KDL-55W805B TV
                                  by YasaCh
                                  Peace be upon you.
                                  Brothers, I need a dump for a Sony LCD smart TV.
                                  Screen type and model: SONY KDL-55W805B.
                                  Please provide a dump for the device.
                                  The device boots up but the SONY logo doesn't appear at first and remains in this state.
                                  04-17-2025, 11:16 AM
