Samsung ue49k6300ak
  • oxonater
    • Oct 2012
    • 77
    • uk
    Samsung ue49k6300ak
    Hi all I have a problem with a UE49k6300ak curve it has audio but no picture.
    BN41-02534B
    I have checked all voltages they seem to be present tv switches on backlights are on and when connected to a source has sound.
    I have replaced the T-con board to no avail, I am thinking the actual main board could be the problem.
    The main board is producing quite a lot of heat is it possible the main chip has lost contact with the board much like graphics cards.
    Also noticed that can't seem to put tv in standby by the power button only by remote.
    much appreciated for any advice.
    Thanks in advance
  • William1967
    • Nov 2017
    • 206
    • Netherlands
    Re: Samsung ue49k6300ak
    Also the display can be faulty, disconnect one of both cables between the t-con and display . Connect the TV to the mains and see what picture you get, after that switch disconnect the other cable and connect the one you disconnected and see what picture you get.
    • oxonater
      • Oct 2012
      • 77
      • uk
      Thanks for your response
      I have tried this as a way of testing for a faulty panel but still back lights on black screen.
      This is so weird TVs was working fine then we had a power cut, then on switching set back on when power was restored this happened.
      Think something on main board has gone pop, and the power button doesn't seem to behave in the way it did previously.
      Have to hold it down for an eternity to get it into standby, were as the remote just works instantly.
      The tcon board has a blue led which is constantly illuminated when switched on but there seems to be another led opposite which never comes on trying to find out what this indicates.👍🏻👍🏻👍🏻
      • oxonater
        • Oct 2012
        • 77
        • uk
        Ok so it appears this TV set caused the power outage basically tripped the RCD in my house.
        So not sure now if it is the main board or something on power board maybe a dodgy diode.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Can you post pictures of your boards and also what voltage readings you have taken along with their designated pin number and names. Perhaps with that information someone may be able to offer further help.
          If it tripped your RCD then I would be suspecting a power supply fault.
          • oxonater
            • Oct 2012
            • 77
            • uk
            Hi here are the voltages from the PSU connector CNM803
            1 NC =0
            2 OD_ON/OFF =3.15V
            3 A13V =12.69V
            4 OD/UD =0.1V
            5 A13V =12.69V
            6 Blu_Pwm =3.29V
            7 A13V =12.69V
            8 Ps_ON/OFF = 3.29V
            9 A13V =12.69V
            10 GND
            11 GND
            12 GND
            STBY 7.5V = 9.3V
            ON 11.8V = 12.69V
            Whilst this Tv did trip my RCD it has now been stable however still no picture but has sound. And the tv/backlights will blink when changing inputs/channels and make the beeping noise.
            Any advice would be greatly appreciated
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              If the backlights are on and staying on but no picture and you have changed the Tcon and also with the power supply readings given looking good (not sure what OD/UD is) then it is looking very much like a main board fault.
              Where do the red, black, yellow, black wires go?
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                looks like the audio output section.
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                • oxonater
                  • Oct 2012
                  • 77
                  • uk
                  Thanks for the responses, the coloured wires go to the speakers.
                  I also am not sure what OD/UD is, is there anyway to test the mainboard.
                  Looking through this forum I cannot see anyone else with this issue and where to start pinpointing a problem.
                  • oxonater
                    • Oct 2012
                    • 77
                    • uk
                    Hi so after getting another Tcon and mainboard this tv is still not playing ball.
                    My question is will the panel be shot or is it something to do with the SMD chips on the boards that connect to panel.
                    I have looked at the tab bonds and they look clean no dirt or but don't suppose you could visibly see any problems.
                    So seems to be a shot panel unless anyone else has any input then think ready for BIN!!!!!!!!!! I HATE THROWING THINGS AWAY
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      Can you post a photo showing how all the circuit boards connect to each other.
                      • oxonater
                        • Oct 2012
                        • 77
                        • uk
                        Hi yes here is a couple of photos not sure how clear they are:-
                        Also included pics of the panel boards which connect to T-con
                        thanks
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          Where does the thinner black cable from the mainboard go? Is it to an ethernet card. If so it may be worth disconnecting it and seeing if the picture will come up.
                          • oxonater
                            • Oct 2012
                            • 77
                            • uk
                            Hi yes already tried that its for the WIFI module, saw tampatec (you tube guy) had an issue with this on a different brand.
                            Did reset tv by the button config method but just hear the sound still no display.
                            Is there anyway to test the boards that connect to panel as I have tried the method of disconnecting these to see if either side produce half a picture still nothing.
                            Its getting to the point of throwing it (OH THE PAIN OF THOSE WORDS)
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              What is the panel number as given on the sticker. Are you 100% certain that the backlights are on and can be seen from the rear of the lcd panel? Do you have full control with the remote ie volume up/down, change source, power on/off?
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                The symptoms I have read here are Backlights ON, Audio ON, Dark screen. Main Bd and T-CON Bd was replaced with hopefully working boards. then this points to a bad Panel. Did you try removing one side of the FFC from T-CON Bd to Panel and then the other side to see if there was any picture at all??
                                • oxonater
                                  • Oct 2012
                                  • 77
                                  • uk
                                  Hi guys yes 100% all backlights are on just displays a lit black screen if this makes any sense.
                                  With regards to testing the panel boards I have tried this, disconnecting each side individually made no difference.
                                  And on some of the threads on this forum people tried this method and had some good results however not in my case.
                                  Not sure if it is the actual panel or something silly like SMD ic on the panel boards.
                                  To think this TV was working fine then tripped my electrics and on switching everything back on tv did this.
                                  Thanks for the input looks like a trip to the dump is on the cards
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    you should try checking smd components on the edge boards near where the tcon to panel / edge boards are connected. Further, at the edge boards, there should be some places where voltages are coming from the tcon (15v or so depending on the panel).... see if you can find such voltage.
                                    further, although most panels display a white screen when the cables are disconnected, some don't as designed. However, those that do... if there is a significant panel / cabling issue at the lower tabs, there are large black areas in cases that I have seen. This to me indicates that the panel is seeing voltage (ie. charge) but no path (thru resistance / capacitance) to "bleeding off" hence the panel section remains black.
                                    • oxonater
                                      • Oct 2012
                                      • 77
                                      • uk
                                      Hi guys well I have put back together at mo as misses giving me stick over having it apart in our bedroom oh dear.
                                      I have post a pic of the actual screen when on looks a lot like backlight bleed has a blue washed out look thanks for your help
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        did you check the fuse / any fuses on the tcon? (on both boards) I guess since the tv is "canned back up", your testing will be limited. You likely need to check for voltages at the edge boards to see if they are getting there. There are some smd components in around those areas that you should check with a meter to see if they are OK.
                                        Lastly, you checked voltages at PSB but did you also check voltages at the main board to see if they made it there and further that they appear at some of the points in the card.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Hi everyone,
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                                          by ygorsan
                                          Hi everyone,
                                          I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                                          🧩 Problem Summary:
                                          • The TV keeps scrolling through the menu or selecting items by itself.
                                          • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                                          • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
